How long did your timing belt last? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-27-2005, 08:45 PM
onioncasserole onioncasserole is offline
onioncasserole is starting off with a positive reputation.
I have 97 Ranger 2.3 93,000 miles. How long did you get out of yours?
Jason
Old 01-27-2005, 09:59 PM
rellik74 rellik74 is offline
rellik74 is starting off with a positive reputation.
my 94 2.3 went 140,000
Old 01-28-2005, 01:03 AM
Draco713 Draco713 is offline
Draco713 is starting off with a positive reputation.
I had a 94 Ranger 4 cyl. that the belt got changed at 74K miles, sold the truck last year with 147K miles on it, never threw the belt. Now I have a 2000 Ranger V6 Flex Fuel 3.0L that I can't help but wonder how long I can go without changing the belt, lol.
Old 01-28-2005, 01:33 AM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
Quote:
i thought the 3.0 L use a timing chain
Old 01-28-2005, 01:39 AM
Talking oops?
Does it??? whoa! ok, that's a new one on me...may explain why I couldn't find it on the maintainance list in the owner's manual, lol.
Old 01-28-2005, 12:24 PM
larpa larpa is offline
larpa is starting off with a positive reputation.
Yes, the 3.0 uses a chain, not a belt.
Old 01-28-2005, 02:35 PM
Lucky you, don't have to mess with that dang belt now.
Old 01-29-2005, 10:39 PM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
I also have a 97 2.3 liter, have 158,000 miles. Never changed the belt, if you read the manual it only tells you to check the belt, there is no mention of changing the belt anywhere in the manual. I just checked mine the other day because I had to remove the timing belt cover to change the thermostat. There were no cracks in it and looked perfectly fine. The belt is relatively easy to change on my truck because I do not have A/C and nothing is in the way. I think I will have my mechanic change it just to be on the safe side next time I have the truck in for something. I would attempt to change it myself, but not sure of myself in getting the timing back to where it suppose to be. I think he wants about $100 to change it.
Old 01-30-2005, 12:25 AM
Quote:
it should be changed about every 100k miles. they are easy to change on your setup, i have the same but its a 91. the only thing that is hard is getting the crank bolt off to remove the harmonic balancer. renting a 3/4" impact wrench should do it though. I can almost guarentee that it will cost you more than $100 to change it unless you have a buddy doing it or something. You can do it yourself. all you have to do to time it is line up the marks on the crank and camshaft, very simple. definatly get it changed either way. if you go ahead and do it yourself and have difficulty, just post here and we can guide you.
Old 01-30-2005, 04:17 PM
ranger1996 ranger1996 is offline
ranger1996 is starting off with a positive reputation.
timing chain
i had mine changed at 143k.......ddnt want to take a chance of it breaking.......found out spark plugs were never changed as well
Old 01-30-2005, 05:46 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
I changed my 93 at 143,000 simply because when it became cold last fall it made a
slight slapping sound like the old nylon tires used to do, until it was warm. It didn't look at all bad and they are the curved tooth which I know from experiance have far more life than the square cornered belts. After it was off I wished I had let it be and see just how far it would go.
Old 01-30-2005, 09:30 PM
Someone told me that if you;ve never changed one before be prepared to make a day of it. Will it really take that long?
Old 01-31-2005, 12:35 AM
Chain, not belt(el con's post)
Yes I am soooo happy about it too. See me dancing?!?! lol Gives me more money and time to play with OTHER things on the truck if I ever get this other problem sorted out (grr!).
Last edited by Draco713; 01-31-2005 at 12:36 AM. Reason: Forgot to note what I was replying to
Old 01-31-2005, 01:24 AM
Quote:
it did for me but i took my time. if you have the proper tools its not that bad. the crank bolt is a beast to get off, if you dont have a 3/4" impact wrench. timing is a snap.
Old 01-31-2005, 03:32 AM
BlueOvalDrifter88 BlueOvalDrifter88 is offline
BlueOvalDrifter88 is starting off with a positive reputation.
My belt went at 145 000kms. Yes kilometers, i dont what that is in miles so i apologize to my friends south of the border. Lucky for me it was only -30 celcius so the repair on the side of the highway was a snap. (say that as sarcastically as you can). It took me a good 5 hours, warming up in my other truck every fifteen minutes. The part that burns me up is the fact the belt blew off 40 000 kilometers early. Does this mean I have a bigger problem, or just bad luck?
Window Sticker paulstravels 2017 Super Duty 35 10-04-2016 01:31 PM
EZ Wiring harness? mountain dewd 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-07-2016 01:25 PM
Odd question... What is the furthest you did, do or would drive your truck? Purplepills 1961 - 1966 F-100 & Larger F-Series Trucks 18 09-18-2015 12:13 AM
How long did your oem belt last? 2002exPSD Excursion - King of SUVs 22 01-09-2014 12:10 PM
How long did you wait before towing? sammy77 2009 - 2014 F150 20 08-27-2013 02:48 PM
Tags
2004, belt, f150, long, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
