How long did your timing belt last?
  #31
Old 02-28-2005, 08:38 PM
Wanted's Avatar
Wanted
Wanted is offline
1992 2.3 Was looking rough at 119,300 so it was replaced.
  #32
Old 03-01-2005, 08:41 AM
Demicon's Avatar
Demicon
Demicon is offline
I have a 4.0L (Traded the 150 in for a Ranger) I hope I have a chain not a belt.
Why on earth would any manufacturer use a timing belt instead of a chain? Is it for more accurate syncronization or something? Think of any mechanical thing.. if it has a belt, that will usually be one of the first things to go.
I guess its to save those pennies on mass production.
As for the life of a vehicle, I would imagine that to be almost impossible to determin, for the reason mentioned above. Not everyone will take care of a vehicle the same.
Honestly, I am baffled.... why a belt?
  #33
Old 03-01-2005, 10:19 AM
el conquistador's Avatar
el conquistador
el conquistador is offline
you have a chain
  #34
Old 03-01-2005, 02:45 PM
kotzy's Avatar
kotzy
kotzy is offline
Let me pass on to you what I've learned about timing belts verses chain. I always knew that engines develope vibrations (harmonics) some undetectable to us. The ones we can't detect are most likely the destructive ones. Using a belt instead of a chain isolates or dampens those vibrations making the engine more durable. Somewhere I read the difference in the lenght of the life of one particular four cylinder chain verses belt, it was unbelieveable what was gained in lower end life. These guys who design engines find out abunchof stuff we never think about.
  #35
Old 03-01-2005, 03:22 PM
texan2004's Avatar
texan2004
texan2004 is offline
Another reason - belts are quiter.
  #36
Old 03-01-2005, 09:05 PM
Demicon's Avatar
Demicon
Demicon is offline
These are some points I never knew of.. or considered.. thanks guys.
  #37
Old 03-01-2005, 10:22 PM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
kotzy pretty much hit it on the head. This was one of the problems with the 427 SOHC with its monsterous 6' timing chain. It was almost impossible to keep the engine in time at high engine speeds, so most of these that were used for racing were converted to a timing belt. There are also timing belt conversions available for SBF and BBF engines as well for race applications.
I think the physical layout of the engine is why the 2.3L uses a timing belt instead of a chain though.
  #38
Old 03-01-2005, 10:37 PM
maticuno's Avatar
maticuno
maticuno is offline
I replaced mine at 98,000 along with the spark plugs.
paulstravels
2017+ Super Duty
44
10-26-2021 07:17 AM
mountain dewd
01-07-2016 12:25 PM
Purplepills
18
09-17-2015 11:13 PM
2002exPSD
01-09-2014 11:10 AM
sammy77
2009 - 2014 F150
20
08-27-2013 01:48 PM
Quick Reply: How long did your timing belt last?
