Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 01-28-2005, 11:00 AM
pops_91710's Avatar
pops_91710 pops_91710 is offline
pops_91710 is starting off with a positive reputation.
I had no idea this thread on this subject even existed until I heard the news reports. I submitted my own story last Feb on how my son's F-150 suddenly burst into flames at 2:00 am one Sunday morning while parked in front of the house. (Thankfully on the street!) Here are those photos: http://community.webshots.com/photo/...12221579STOEau
Now, I wonder if we can nail Ford for the out of pocket expenses the insurance company didn't cover?
__________________
2003 Ford F-250 S/D XLT SC, 4X4, 6.8 V10 Triton, 4.30 axles w/Gear Vendors overdrive. Firestone 265/75R16 Transforce HT. Pullrite 16k Super 5th hitch/2006 Cardinal 30LE WB
Mike Harrington
  #62 (permalink)
Old 01-28-2005, 11:03 AM
fbodyfan fbodyfan is offline
fbodyfan is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Aftrmidnite
Quick question; there are two locking tabs, one at the front, one at the back of the switch. Do you squeeze them in or spread them to get the connector to release?
You squeeze them together. It may be a little hesitant to move, but keep in mind this is probably the first time that switch has ever been disconnected, so bear with it, but you squeeze the tabs inward to unhook it.
  #63 (permalink)
Old 01-28-2005, 11:46 AM
scort71 scort71 is offline
scort71 is starting off with a positive reputation.
thanks for the picture!!! helps alot racerguy
  #64 (permalink)
Old 01-28-2005, 01:27 PM
50th ann 50th ann is offline
50th ann is starting off with a positive reputation.
Cruise Control Switch Recall
Finally Ford will have to admit there is a problem but only on the 2000 year model.
What about my 1998 F-150 that filled my garage with smoke over night. It's not just the 2000 model. I replaced the switch but is the new one safe.
I would change the switch again if a new switch will fix the problem.
I ideas or more information would be appreciated.
__________________
1998 F150 4.6L 2WD Ext Cab Purchased New
50th Anniversary Edition Lariat
Automatic 235,000 Miles
2007 Harley Davidson Ultra
2007 E350 Mercedes Benz
1969 Plymouth Roadrunner
  #65 (permalink)
Old 01-28-2005, 02:09 PM
couleeman's Avatar
couleeman couleeman is offline
couleeman is starting off with a positive reputation.
You can call and see if the part numbers are the same for the years. If they are, then most likely they are the same switch.
__________________
Just slap me, I'm not listening anyway
03 GMC, don't blame me, Tequila was involved...
  #66 (permalink)
Old 01-28-2005, 02:35 PM
gui88ford's Avatar
gui88ford gui88ford is offline
gui88ford is starting off with a positive reputation.
what about 01...are they part of the recall because my CC doesn't work sometimes and i did notice a hot smell every once and a while a couple months ago
  #67 (permalink)
Old 01-28-2005, 03:01 PM
couleeman's Avatar
Quote:
Take it in right away. That is the reason for the recall and the warning signs of the potential fires according to one of the articals I read on it. What the dealer will do is disconnect the CC until they get a new switch for you then they will put a new switch in for you.
__________________
  #68 (permalink)
Old 01-28-2005, 03:04 PM
MBDiagMan MBDiagMan is offline
MBDiagMan is starting off with a positive reputation.
Only the Super Crew cab in '01 is covered by the recall. They would do it, but they would charge you for it.
Simply disconnect the connector at the mc switch and look inside to see if it is dry. If it is bone dry, put it back together. Yours is not identified as one with the bad switches. It doesn't hurt to do periodic inspection for the safety of it.
Good luck,
Doc
__________________
Doc
ASE Master
1964 Galaxie 500 Fastback
1978 F150 Shortbed 4X4 that I bought new.
2000 F150 RC, Flareside, 4.6, 5 speed 4X4
2006 Mustang GT, 3 valve 4.6, 5 speed manual
Other vehicles of blashemous make other than Ford
  #69 (permalink)
Old 01-28-2005, 08:42 PM
BSHORT BSHORT is offline
BSHORT is starting off with a positive reputation.
I Unhooked My Switch Today And There Was No Fluid Inside. It Will Stay Unhooked Until Ford Advises Me Of The Recall And The Status Of The Parts. Better Safe With No Cruise Than Sorry With A Melted Hunk Of Truck. Keep In Mind, The Switch Is Similar In Appearance To Some Superduty's. So Far It's Unclear If It Was Just A Bad Batch Of Switches Or If It Will Affect All Models. Keep Your Fingers Crossed.
  #70 (permalink)
Old 01-28-2005, 10:24 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Today at the dealership I work at we got the recall notice from Ford. I performed the first one in our shop today. We are to unplug the connector, tape it up to keep dirt etc out of it and tie-strap it to keep it from dangling. The new switches are supposed to be out in April.
It only takes a few minutes to do the recall but your dealer might need it longer depending on how their schedule is.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #71 (permalink)
Old 01-29-2005, 06:48 AM
I am starting to read PANIC on this site and another Ford site. DON'T PANIC! It is VERY simple to simply disconnect the connector that is in Racerguys drawing and look into the switch to see if it is dry. Anybody can do it.
Even if you don't have a 2000 model, disconnect and see if the switch is dry. If you are really a paranoid type, then just leave it disconnected. As Racerguy said, you should tape it up so it will stay clean.
DON'T PANIC, BE CALM!
__________________
Doc
ASE Master
  #72 (permalink)
Old 01-29-2005, 08:14 PM
cboyd cboyd is offline
cboyd is starting off with a positive reputation.
MBDiagMan,
Yes, there was enough brake fluid pooled in the connector on the sensor for the connector to drip brake fluid when I removed it. The connector was not melted on either the sensor or the lead and I noticed no arc marks or burn marks. Also, the 20A fuse was not blown. But, you're right, I probably did get lucky.
I had noticed cruise control stopped working last week, when I was going to work and tried to activate it to avoid getting a speeding ticket :-). It didn't work and I mentioned it to my partner. Thursday night, she was watching the news and they said that all of the fires to date were preceeded by cruise control failing. So, I then figured out how disable it.
I cleaned the connector as well as I could (it's hard to do, because it's a narrow female connector) and then taped it up with electrical tape. Then I tie strapped the connector to cruise control throttle control cable (dunno the precise name - it's what the servos use to transfer power to the throttle adjustment located new the right head). I did this to point it away from the wheel well, which from the stories I read also plays a role. The connector is about halfway between the master cylinder and the power steering reservior. If it catches and drips now, hopefully it will drip flaming plastic on something that's not flammable.
I then wrapped some electrical tape around the connector on the sensor and put a tie strap on to hold it in place. This is to keep the dirt out. Eventually, whenever they release a non-defective sensor, I'll end up swapping them out. Ford, being the cheapskates they are, will probably not cover my 2001 Supercab, so I'll probably have to foot the ~$30 for the sensor.
Anyways, just to be on the safe side, I am conciously parking it away from the house, just in case. But I think I've reduced the risk quite a bit. Your mileage might vary. I actually thought at one point about just cutting the connector off and taping them up, and then replacing it when I buy the fixit kit (I think it comes with a replacement connector which gets spliced in).
BTW, here are the stats:
4.6L V8
2001 Ford Supercab XLT
Approx. 74,000 miles.
Automatic Transmission (but don't know which one?)
*** I think it was manufactured in 2000 and sold in 2001? It is a 2001 model year, however.
I will try to post any part numbers I can read from the sensor. I don't see a reason why Ford would fundamentally change a minor sensor when the whole truck's design is basically the same, so I think this is probably exactly the same sensor as 2000 models. Didn't the previous last redesign happen in 1996 or 1997?
  #73 (permalink)
Old 01-29-2005, 08:23 PM
With your cable taped and tied away from the switch, there is absolutely no need to park the truck away from the house. You have disabled the possibility for a fire. You did exactly what the dealer would have done.
Now just sit tight 'til they get the new switches in April.
Have a great day,
Doc
__________________
Doc
ASE Master
  #74 (permalink)
Old 01-29-2005, 09:48 PM
Brett99's Avatar
Brett99 Brett99 is offline
Brett99 is starting off with a positive reputation.
I disconnected mine just in case since mine is parked in garage. Mines a 2002 and was dry but I don't use CC much so better safe then sorry
  #75 (permalink)
Old 01-30-2005, 12:28 AM
snoVVman snoVVman is offline
snoVVman is starting off with a positive reputation.
I'm visiting from the Expedition/Navigator Forum. I have a 2002 Navigator and it has what appears to the be same switch. I know Ford has not included 02s in its recall but I can't imagine that the 02s have an updated version of the switch. What gives?
I did check the switch and it appears to be completely dry. No signs of brake fluid.
JAMES.
Tags
2003 , control , cruise , f150 , ford , recall , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
