Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 01-27-2005, 02:25 PM
kkja kkja is offline
kkja is starting off with a positive reputation.
Question
From what I've read they will disable the cruise control system for now until they get enough switches in stock to replace them all. Then they will call you back.
I'm wondering if I could just pull a fuse or something so that I don't have to make 2 trips to the dealer?
Does anyone know if there is an easy way do disable the system w/out having to go to the dealer?
  #32 (permalink)
Old 01-27-2005, 02:40 PM
MBDiagMan MBDiagMan is offline
MBDiagMan is starting off with a positive reputation.
While in town for a trip to the bank I heard the same news. I stopped at the Ford house and the service guy didn't know what I was talking about. He got the vin and ran an OASIS and sure enough it showed up. It said that it is the speed deactivate switch and that it is to be disonnected and taped until the new parts come in April. He had no tech available so I said that I would do it myself.
I then heard on the next news broadcast that in all cases the CC has failed BEFORE the fire occurred. Since my CC is still working fine I am not going to disconnect the switch. In my case I have a manual transmission so I think I will have to do this to both of the speed deactivation switches, brake AND clutch.
Even though my CC still works well, this is a little worrisome since I keep this truck in my shop where my 35 year collection of tools equipment, woodworking shop, welders, etc are located. If it went up the truck would probably get replaced, but my shop full of stuff took me a lifetime to collect.
Have a great day,
Doc
__________________
Doc
ASE Master
1964 Galaxie 500 Fastback
1978 F150 Shortbed 4X4 that I bought new.
2000 F150 RC, Flareside, 4.6, 5 speed 4X4
2006 Mustang GT, 3 valve 4.6, 5 speed manual
Other vehicles of blashemous make other than Ford
  #33 (permalink)
Old 01-27-2005, 02:49 PM
Tell3131 Tell3131 is offline
Tell3131 is starting off with a positive reputation.
http://money.cnn.com/2005/01/27/pf/a...ex.htm?cnn=yes
  #34 (permalink)
Old 01-27-2005, 02:58 PM
fbodyfan fbodyfan is offline
fbodyfan is gaining momentum as a positive member of FTE.
Have a great day,
Doc
Ouch. If I were in your shoes, I'd play it safe and not keep my truck there, or disconnect the fuse despite the fact it still works. It said all cases, but its not worth taking that risk that you could be the first to have a fire when it was working fine. Crap. I gotta take mine in
  #35 (permalink)
Old 01-27-2005, 05:01 PM
stategame stategame is offline
stategame is starting off with a positive reputation.
fire!!!!!!!
I called ford after the notice , they did't know, so I sent them the article.as noted in the other messge, PULL THE FUSE NOW !!!!! remember the wipers ? I saw two fires (not on mine) before that recall. thanks
  #36 (permalink)
Old 01-27-2005, 05:14 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is gaining momentum as a positive member of FTE. BillyBob69 is gaining momentum as a positive member of FTE.
OK Now I am beginning to get worried....What differences are there between the 00, 01 vs the 02 F150's concerning the CC? Any final word as to the years? I read the article and it only mentioned the 01s and 00s, but its still a little close to just blow off and not worry about.
__________________
99 F350SD Lariat Crew Cab
7.3L PSD - 4x4
I got a truck for my wife...Good trade huh?!
  #37 (permalink)
Old 01-27-2005, 05:22 PM
trk98 trk98 is offline
1989 Ford F-150
trk98 is starting off with a positive reputation.
i heard on the news radio of a factory recall on this exact problem u are having. sorry if this is a repost
  #38 (permalink)
Old 01-27-2005, 05:55 PM
gui88ford's Avatar
gui88ford gui88ford is offline
gui88ford is starting off with a positive reputation.
stinks like burning
this recall for the CC......i have an 01 4.6 L 5spd......my cruise shuts off sometimes, then comes back on, an sometimes i smell it....like it's burning....with hearing all of this about the recall.....does anyone know if 01 reg. cabs are included in the recall.....i seen that it was only supercrews from 01
thanks
  #39 (permalink)
Old 01-27-2005, 06:46 PM
The difference probably the switch. I learned alot more on another site where Ford techs hang out.
The problem is a bad pressure switch on front of the master cylinder. The circuit that freeds it is a 20 Amp circuit that is always hot, ignition on or not. The defective switch will start shorting which produces heat in the brake fluid which is a combustible fluid.
I went out and felt of this switch and it was ice cold, but I disconnected the connector anyway. I use my CC alot, but it's just not worth the risk to me. I will do without it until April. That's when the new parts will be available.
Good luck and hope this helps,
Doc
ASE Master
__________________
Doc
ASE Master
  #40 (permalink)
Old 01-27-2005, 07:06 PM
They are NOT included in the recall. If you want to relieve your worry, simply raise the hood, disconnect the connector from the pressure switch at the front of the master cylinder and look into it with a flashlight to ensure that it is dry. If it is wet, that fluid can combust due to the 20 Amp always on circuit that feeds it.
Good luck,
Doc
__________________
Doc
ASE Master
  #41 (permalink)
Old 01-27-2005, 07:58 PM
monckywrench monckywrench is offline
monckywrench has a good reputation on FTE. monckywrench has a good reputation on FTE.
I will be giggling like a schoolgirl when they have to recall even more vehicles with the defective switches they have been installing for years.
http://www.poynter.org/column.asp?id=2&aid=77567
"You will remember that back in December Al's Morning Meeting told you about an investigation that WESH-TV in Orlando was working on involving Ford F 150 trucks that were bursting into flames even hours after they were parked and turned off.
Yesterday, Ford recalled 792,000 of the popular trucks and SUVs.
Just as WESH reported months ago, the problem appears to be in the cruise control switch."
  #42 (permalink)
Old 01-27-2005, 08:15 PM
mikewrt's Avatar
mikewrt mikewrt is offline
mikewrt is starting off with a positive reputation.
FYI F150s . . . RECALL!!
I'm sure many of you have heard this already . . . If not you may want to read this article on a recall for 2000 F150s.
http://www.msnbc.msn.com/id/6876176/
Hope this helps some of you.
__________________
mike
'03, f250, 6.0, 5 speed auto, Crew Cab, FX4, Short Box, Silver
Autometer gauges pyro, trans, boost, water temp, volt meter
4" MBRP turbo back, DieselSite coolant filter, Mag Hytec diff cover
Door keypad, silver stars, custom intake with stock filter, Fumoto valve, BD Diesel IC boots . . .
  #43 (permalink)
Old 01-27-2005, 09:13 PM
Mean Bone Mean Bone is offline
Mean Bone is starting off with a positive reputation.
RECALL is serious - (pics)
A co-worker and friend was inside his house one evening a couple of weeks ago when he heard something he didn't like. Going into his garage he found flames coming from the driver's side front wheel well of his 2000 F-150! He exhaused two fire extinguishers with no effect. The fire continued up into the attic shuttle hole in the ceiling of the garage. Once inside the attic it immediately spead across the entire length of the house dropping fire onto the ceilings below. The family lost everything except some baby pictures on a CD and their wedding album.
http://img.photobucket.com/albums/v1...F-150firea.jpg
Here's the garage where the fire started.
http://img.photobucket.com/albums/v1...firegarage.jpg
You can see the trailer hitch to his F-150 under the garage door:
http://img.photobucket.com/albums/v1...ailerhitch.jpg
So . . . if you've got a 2000 F-150 you might seriously consider getting it fixed or at least park it outside your garage! I don't believe he had any problems with his cruise control before the fire.
__________________
MB
2000 F-150 XLT 4x4 SCab
5.4 V8
3.55 LS
Tow package
Chestnut/Beige
Cloth Capt Chairs
6 CD changer w/tape
Delphi XM SkyFi
TracRac w/toolbox
  #44 (permalink)
Old 01-27-2005, 09:14 PM
BSHORT BSHORT is offline
BSHORT is starting off with a positive reputation.
Thanks For The Heads Up...i Hadn't Heard. I Have An 01' Screw And It Looks Like It Will Be Affected Too. Hope It Doesn't Melt Down Before I Get It Taken Care Of.
  #45 (permalink)
Old 01-27-2005, 09:35 PM
NEW4X4 NEW4X4 is offline
NEW4X4 is starting off with a positive reputation.
Getting Nervous, Just Moved The '01 S-crew Away From The House.
In Reading All Of This, Is It Just The Switch On The Master Brake Cylinder Where The Cruise Disconnect Switch Is Located?
Tags
2003 , control , cruise , f150 , ford , recall , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
