Vacuum diagram 2.5L 1998 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-27-2005, 07:52 PM
johnsjmc johnsjmc is offline
johnsjmc is starting off with a positive reputation.
I have a vacuum tube T on the passenger side below the air box . Does anyone know where it goes to?
Old 01-27-2005, 07:54 PM
pintopower8 pintopower8 is offline
pintopower8 is starting off with a positive reputation.
that wouldn't be the EGR would it?
Old 01-27-2005, 08:07 PM
Dave257 Dave257 is offline
Dave257 is starting off with a positive reputation.
The only T I see on the diagram is one that goes from the vacuum reserve tank under the passenger side fender and the 4X4 hub solenoids and the line that goes into the cab for the heat/air box.
Dave
Old 01-27-2005, 08:52 PM
The truck is 2WD ,one end might go into the fender (probably the vac tank ).Maybe one end should be capped as it might be intended for the hubs on 4WD ? Where do I find a diagram? The one on the rad cradle is little help.
Old 01-27-2005, 09:10 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
You should have one under the hood on the radiator support.
'73 460 vacuum advance kermit Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 04-19-2004 12:35 AM
vacuum diagram steve83 1987 - 1996 F150 & Larger F-Series Trucks 4 01-13-2003 05:34 AM
Vacuum advance problems atblis 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 08-02-2001 11:21 PM
Vacuum hose routing diagrams secondstar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-24-2001 11:22 AM
Emissions vacuum lines TallPaul Ford Inline Six, 200, 250, 4.9L / 300 9 03-08-2001 06:50 AM
Tags
1998, 25, 25l, 98, diagram, diagrams, f150, ford, ranger, schematic, vacum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
