Torque specs needed for 351 Cleveland - Ford Truck Enthusiasts Forums
Old 01-27-2005, 10:33 AM
fordtruckman838 fordtruckman838 is offline
fordtruckman838 is starting off with a positive reputation.
Does anyone have the torque specifications for a 74 351 cleveland. I need just about all of the specs including the intake manifold progression
Old 01-27-2005, 08:20 PM
FordTruckTechNut FordTruckTechNut is offline
FordTruckTechNut is starting off with a positive reputation.
<TABLE cellSpacing=0 cellPadding=4 width="100%" border=0><TBODY><TR><TD width="51%" bgColor=#163d67>
Fastener Type
</TD><TD align=right width="39%" bgColor=#163d67>
Torque Spec.
</TD></TR><TR><TD width="51%" bgColor=#163d67>Main cap bots</TD><TD align=right width="39%" bgColor=#163d67>95-105 ft.-lbs.</TD></TR><TR><TD vAlign=top width="51%" bgColor=#163d67>Connecting rod bolts</TD><TD align=right width="39%" bgColor=#163d67>40-45 ft.-lbs
45-50 ft.-lbs
for Boss 351C
</TD></TR><TR><TD vAlign=top width="51%" bgColor=#163d67>Cylinder head bolts (follow factory torque sequence)</TD><TD align=right width="39%" bgColor=#163d67>105 ft.-lbs.
125 ft.-lbs for
Boss 351C
</TD></TR><TR><TD width="51%" bgColor=#163d67>Rocker arms (non-adjustable)</TD><TD align=right width="39%" bgColor=#163d67>18-22 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>5/16" Intake manifold bolts</TD><TD align=right width="39%" bgColor=#163d67>21-25 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>3/8" Intake manifold bolts</TD><TD align=right width="39%" bgColor=#163d67>28-33 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Oil pump bolt</TD><TD align=right width="39%" bgColor=#163d67>25 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Cam bolts</TD><TD align=right width="39%" bgColor=#163d67>40-45 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Cam thrust plate bolts</TD><TD align=right width="39%" bgColor=#163d67>9-12 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Harmonic damper bolt</TD><TD align=right width="39%" bgColor=#163d67>70-90 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Flywheel/ flexplate bolts</TD><TD align=right width="39%" bgColor=#163d67>75-85 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Pressure plate bolts</TD><TD align=right width="39%" bgColor=#163d67>35 ft.-lbs.</TD></TR><TR><TD width="51%" bgColor=#163d67>Front cover bolts</TD><TD align=right width="39%" bgColor=#163d67>12-18 ft.-lbs.</TD></TR></TBODY></TABLE>that should doit. as for progression start with half of the desired torq start in middle and work your way out in a criss cross circle.
351 Cleveland 2BBL stock horspower? pickenspolitics 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-19-2013 01:52 PM
400 vs 351c 2V heads Hooker Bob 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 06-15-2005 05:50 AM
351: Cleveland or Windsor? calazo Performance & General Engine Building 16 06-23-2004 04:46 PM
351c specs scottjohn Performance & General Engine Building 2 09-22-2002 01:06 AM
HP & torque from a 351? puffc 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 10-18-2000 03:38 PM
Tags
1973, 351, 351c, bolt, cleveland, engine, especs, ford, head, sequence, specification, specifications, specs, tork, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
