Oil in Coolant - Ford Truck Enthusiasts Forums
Oil in Coolant
Old 01-27-2005, 11:21 AM
tomd tomd is offline
tomd is starting off with a positive reputation.
Oil in Coolant
Hi,
Got a 97 Ford Ranger 4 cylinder last year. Noticed that the coolant looked funny when I got it, but only got around to flushing it this year. It looked like there "might" be oil in it. It was very brown, but the oil wasn't floating on top like I would have expected. Does the coolant cause the oil to mix in real well, or is this just some really funky coolant?
Is there a common problem with this version of the 4 cylinder to cause the head to crack or the gasket to go?
Thanks!
Tom D
Old 01-27-2005, 03:06 PM
Quote:
Originally Posted by 91 Ranger Turbo
Change and flush your coolant system.
Then check it again it maybe dirt or rust in there.
If it is milky than you have a cracked head or gasket.
Definitely not milky. I did flush my system about four times, and it slowly got better (of course there is the fluid in the engine itself that doesn't drain out, so it took a number of cycles to get it even somewhat clean).
I am leaning toward rust/dirt, as it didn't look anything like a water and oil mix that I have seen, but I thought that maybe the coolant allowed the oil to mix more normally. I might just mix up some coolant and water tonight and see what it looks like to convince myself that wasn't it.
The coolant basically had the same consistency of normal coolant, but was dark brown rather than green.
Thanks,
Tom D
Old 01-28-2005, 07:53 AM
91 Ranger Turbo 91 Ranger Turbo is offline
91 Ranger Turbo is starting off with a positive reputation.
pull your radiator off and flush it really good with some chemicals. Or just flush it with a water hose and re-install it.
Head gaskets? ROBBINthaHOOD Modular V10 (6.8l) 3 11-11-2016 11:57 AM
01 Excursion V10 White smoke out exhaust ROBBINthaHOOD Modular V10 (6.8l) 5 11-10-2016 06:42 PM
2010 still smokes after egr delete jewel57 6.4L Power Stroke Diesel 8 03-28-2016 02:58 PM
03 Sport Trac radiator crud av8tor09 Explorer, Sport Trac, Mountaineer & Aviator 3 08-26-2015 05:21 AM
Cost to rebuild a 7.3? Baatzy 1999 - 2003 7.3L Power Stroke Diesel 15 04-22-2015 12:57 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
