help- smoking starter - Ford Truck Enthusiasts Forums
Old 01-27-2005, 07:27 AM
maxidog-ranger maxidog-ranger is offline
maxidog-ranger is starting off with a positive reputation.
Unhappy help- smoking starter
92 ford ranger 2.3- problem started yesterday. Starter will turn over and then after truck cranks starter keeps on turning. i replaced the starter last night. Made mistake of not marking which post battery to starter red wire goes on the solenoid. put neg back to battery; heard a clicking sound ; tried to crank but would not do anything. then started smoking at starter.What did i do wrong? .Thanks in advance everyone........Jimmy
Old 01-28-2005, 07:54 AM
91 Ranger Turbo 91 Ranger Turbo is offline
91 Ranger Turbo is starting off with a positive reputation.
it sounds to me like you smoked your new starter. Take it off and see if they can exchage it for a new one.
Old 01-29-2005, 10:25 PM
vekrause vekrause is offline
vekrause is starting off with a positive reputation.
Your relay is stuck, you need to replace it or you'll keep frying starts (when it happened to me I had the key out of the ignition and the starter still kept going.) For my '91 it was an easy fix, its bolted to the right fender with some heavy gauge wire going to it.
Good luck
Old 02-01-2005, 02:57 PM
Update-smoking No More= Fixed
:-d Took Starter Back And They Tested It At Store- Smoked For Them Also. Swapped Starters And No Problem . Thanks Everyone
1999 f150 starter is good but wont start. taylerallen6 1997 - 2003 F150 8 06-21-2016 07:45 PM
Starter solenoid? Checking starter? mOROTBREATH 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 09-24-2013 08:01 PM
1974 F250 Electrical problem Arizcoin 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-07-2013 09:27 PM
no crank...no start, with lights. gvrangr98 Ranger & B-Series 3 03-24-2010 08:15 AM
1991 Ford F150 not starting milkbone 1987 - 1996 F150 & Larger F-Series Trucks 2 10-07-2006 07:41 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1977, 72, batterie, battery, expedition, explorer, f150, f250, ford, pickup, ranger, smokes, smoking, starter, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
