2000 Ranger Transmission Problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-26-2005, 07:53 PM
michiganweirdo michiganweirdo is offline
michiganweirdo is starting off with a positive reputation.
Question 2000 Ranger Transmission Problems
Ok it just might be the transmission is on its last leg but I need help.
As of Sunday the Overdrive light is flashing periodically. Not every time but I would say about 50% of the time.
And now I noticed that its not catching gears as easy as it used to now the motor revs to about 3000 RPM's and barely catches from 1st to 2nd. If I let off the gas it will catch. Between all gears its seems to be doing the same thing.
Are the 2 problems related? Any help wpuld be appreciated. Will trans cleaner/treatment help Here are the vitals on the truck
2000 Ford Ranger Extended Cab
2WD
180,000 Miles.
Yes I am still paying on it
Old 01-26-2005, 08:22 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE ..
Old 01-26-2005, 09:44 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Is the fluid level OK? How does the fluid look? Has it been flushed regularly?
The flashing OD indicates the PCM my have a code, some parts store will pull the codes for free.
Old 01-26-2005, 10:35 PM
just did a 14 point oil change (and radiator flush) fluid level is clean and a lil over full thats why I dont wanna put the cleaner in there yet til that goes down. I might have em flush it this w/e. 180,000 is pretty good though even if it does go out. but I want it to go MORE MORE MORE I wanna go to 1,000,000 miles darn it. I will go back to Auto Zone and have em read it. I wasnt sure if it would come up with anything since its not a check engine light problem.
Last edited by michiganweirdo; 01-26-2005 at 10:38 PM. Reason: add another portion
Old 01-26-2005, 11:18 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
Quote:
if you are talking about the codes, you can have codes with or without a CEL.
Transmission problem?? Help needes Chrisgallo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 08-28-2016 09:46 PM
Transmission is a goner. Rip. What do I do now? Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 07-04-2015 07:02 PM
Power steering problems lstr81 Escape & Escape Hybrid 3 06-23-2015 08:18 AM
Full Tranny Fluid Pump Out pawpaw Ranger & B-Series 17 04-26-2014 09:52 PM
Another E4OD Trans Problem! slwsmkn444 1994.5 - 1997 7.3L Power Stroke Diesel 12 09-21-2009 07:20 PM
Tags
180000, 2000, 30, auto, ford, issues, miles, problems, ranger, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
