Ford Truck at Auction -
Just wanted folks to know a Ford Truck is comming up at Auction TONIGHT January 26, 2005
http://kmonkauctions.com/jan25.htm
(Yes, it is mine)
(Yes, it is mine)
Update - Trunk did NOT sell. NO Serious buyers - bidding started at 100 and went to $350. Very dissappointing. Especially when you consider what I have put into it.....
1999 - Fixed cab corners and box wheel well fenders with proper patch panels.
1999 - New belts and hoses.
Regular oil and filter changes.
1999 - Rebuilt bottom end of motor and replaced crank, bearings, timing gears, chain and oil pan.
Front tires were new a year ago and are 100,000 KM rated Hercules Tires. Brakes are almost entirely new - new master cylinder this year. The only things I think that haven't been replaced are the front rotors (they should be replaced) and calipers. Rear brakes have been re-done in stages over the last 5 years including new pads, springs & Drums.
2000 - New fuel tank
2004 - Carburetor replaced with rebuilt.
2001 - Inside of truck box and bed repaired and repainted. Box Liner Installed.
2002 - Tailgate top protector
2001 - Front end work - NEW King Pins and front alignment.
2003 - New vacuum modulator on transmission, new fluid and filter.
2002 - New Muffler
2003 - New exhaust pipe from muffler back including stainless tip.
2004 - New rotor, distributor cap and plug wires.
2003 - New Coil
2004 - New Ignition Module
2003 - New Water Pump
2004 - New Alternator
2002 - New Muffler
2003 - New Coil
