Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 01-28-2005, 06:21 PM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is starting off with a positive reputation.
Quote:
Originally Posted by tn mac
I agree not quite the same but it gets the fluid pretty hot, and it also gets dirty, guess this is one of those times we agree to disagree. would that be a another time warp thing, ha ha.
For sure!
But that is why I looked at and sniffed the tranny dip stick. (keep it clean you guys!) If the fluid was dark and smelled burned. I would have went for the flush. I went about 90,000 miles on my Bronco with AOD and had been in the mud and 4WD the heck out of it. I pulled the tranny dipstick and it smelled really burned and was dark brown. I flushed it but didn't let them use any flush chemicals just tranny fluid. Worked out great.
__________________
03 F250SD 4X4 6.0L PSD 5speed auto. 3.73 diff, extended cab, Raven shell. 4/2/03 build, 3/27/03 engine build.
  #17 (permalink)
Old 01-28-2005, 09:32 PM
tinytrixie's Avatar
tinytrixie tinytrixie is offline
tinytrixie is starting off with a positive reputation.
Quote:
Originally Posted by SBV45
In Central Texas I found Mercon SP at a local parts house that is owned by Arnold Oil company, a local distributor.
The 30k maintenance only calls for a drain and fill and external tranny filter change. The flush is extra and not necessary. I did the drain and fill. It took 8.25 quarts. I know a local trans shop that won't do the flush.
I think the reason that some don't recommend changing all the fluid is that atf has very high levels of detergent (probably common knowledge here) and all replacing all the fluid will remove built-up varnish causing increased tolerances that could only lead to no good. My personal opinion on automatics is if you are going to flush, do it more often than prescribed preventing or at least slowing normal wear & tear and varnish buildup from the get go. I don't know if it was SB ot KW that rotates between flush and drain & fill but I like that idea for these high tech tranny's. If I am going to overkill on fluids I will do it there b4 the oil (I do it there also) because I love the truck!
__________________
2004 F250 04/'04
  #18 (permalink)
Old 01-28-2005, 10:00 PM
mark bondlow mark bondlow is offline
mark bondlow is starting off with a positive reputation.
I can't confirm this, but a guy at the local trans. shop told me that if you change the tranny fluid too often the detergent eats up the clutch plates.
__________________
05 e-350 cutaway with kuv body. Alum. wheels interior and exterior upgrde pkgs, 6.0 with 9600# spring pkg. Cruise control, electric tow mirrors, 5 speed t.s. . 1000# tommy lift. Class 7 rec. hitch.
  #19 (permalink)
Old 01-28-2005, 10:51 PM
Springer Springer is offline
Springer is starting off with a positive reputation.
I once had an F-150 that was a really good truck. I loved it until I had the tranny flushed at 75k. A week later it started slipping and I barely made it to a pay phone before all the fluid came out the bottom popping and hissing as it hit the wet ground. Naturally, I was on a rescue mission to pick up my wife, kids and in-laws as the wife's Nissan van had lost it's fans and overheated 40 miles from home and was now awaiting repair. After getting home I discovered the heat pump had thrown craps and needed repair. Three grand plus in repairs in one day and the in-laws were still there. Among other things, I suddenly hated that truck!
Of course, after the fact, several folks pointed out that I should never have flushed the tranny at 75k. I should have done it sooner or not at all. Jeez, I just love all the advice as I write the check...
__________________
'05 F-350 6.0 LB CC SRW KR with all the factory goodies
  #20 (permalink)
Old 01-28-2005, 11:09 PM
SBV45's Avatar
Drain and fill is all that is required. Of course you can spend your money any way you want.
__________________
  #21 (permalink)
Old 11-01-2009, 10:34 PM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
Fellas,
A couple quick questions regarding my transmission leaking fluid. I have a 2005 PSD FX4. I just recently had my transmission serviced out of town. When pulling a trailer, I noticed a lot of fluid coming from the transmission. I can not tell exactly where it is coming from. My understanding is, there is a vent on top of the tranny that will release excess fluid. I am assuming it was overfilled. When checking the fluid level, letting it cool overnight, the dipstick still shows it to be full. THis has happend several times, but the stick continues to show that is is full. The truck runs great, other than the fluid coming out I can't tell that there is a problem and this did start immediately after it was serviced. Questions are,
1. Will having the excess fluid harm the truck? Or does the overflow vent correct the problem by default?
2. Do yall recommend starting over? Drain, flush, and put back in the correct amount?
3. Ok ,the manual calls for MERCON SP. The guy at the local transmission shop (not the one that serviced it to cause the problem) said he does not carry regular MERCON SP but uses the synthetic version. Does MERCON SP-"Synthetic" exist, I haven't found any info on this? Or is MERCON SP already a synthetic and the fella is just confused?
Any input on this one would be greatly appreciated. Thanks
Tags
automatic , buy , engine , fluid , flushing , ford , information , mercon , merconsp , mixing , msds , oil , sp , transmission , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
