2005 6disc mp3 player problems
I'm sure I closed them out. As cheap as CD-R's are, there is no reason to do several sessions on one CD. I can understand if the unit is a little quirky, but I just want to know what the combination is. I'm going to test out Pittsburgh's theory on the types of burners and formats. Hopefully that is the final definitive answer. God knows Ford doesn't know or doesn't want to acknowledge that there are any flaws with the unit.
Thanks Pittsburgh-05HD. Have you done anymore research on it? Hopefully I will be able to burn some this weekend and make a list of what works and what doesn't.
This unit can play MP3 and WMA files recorded on CD-ROM, CD-R, and CD-RW discs in ISO9660 Level 1/Level 2, Joliet, and Romeo formats.
Update - GOOD NEWS!!!
I burned some test MP3 CD's tonight and they all worked!!! Here is a list of the combinations I tried. All discs were Memorex 80 min. CD-R burned at 52x:
Joliet 128kbps
Joliet 192kbps
Joliet 256kbps
Joliet 320kbps
Romeo 128kbps
Romeo 192kbps
I used "Disc-At-Once" when I burned each of them. I started out with just one song, no folders. But after I saw that it read all of them, I made a CD in Joliet format with 2 folders, one song in each (one at 128kbps and one at 192kbps). It read the folders and the files just fine. I think the problem before must have been that I was using some 24x discs. The 52's work!
Joliet 128kbps
Joliet 192kbps
Joliet 256kbps
Joliet 320kbps
Romeo 128kbps
Romeo 192kbps
The manual may have one sentence on the MP3's. It doesn't even say much about the changer. UPDATE - I copied a CD directly to a CD-R at 52x and tried it this morning. Again, Memorex 80min. 52x; it played fine for about 5 minutes, then it started the digital skip a little... and then a lot. I ejected it before the unit called it a bad disc, but I'm sure it was soon to happen. So, I sorted out the MP3's, but I have to figure out the combination for CD's now. This is a lot of work to get an OEM unit to work properly!!!
Mine started doing the digital skip and spitting out some store bought discs, and CDA made discs. They played fine for a while, but then one day it wouldn't play it anymore. I just haven't taken the time to go to the dealer with it yet. I think this is unacceptable from something that should just work. If it required specific CD burning processes, I would expect it to be covered in the manual which it is not.
FarmForward
07-10-2011 08:01 PM
CentralCoaster
2004 - 2008 F150
15
03-15-2005 07:58 AM
