Coil problems - Ford Truck Enthusiasts Forums
Coil problems
Old 01-25-2005, 02:48 PM
bumpwhite bumpwhite is offline
bumpwhite is starting off with a positive reputation.
Coil problems
During Christmas, I lost two coils simultaneously. It appears to have occurred when I went to two wheel drive from four wheel drive. I thought it may have been coincidental so when I got my truck out of the shop, I put it into four wheel drive then back into two wheel and the truck started to miss and about 30 minutes later the check engine light came on. Taking it back to the shop, one coil was bad on the same cylinder as was previously replaced. The repair work was not done at a Ford dealership.
Is it possible switching from four wheel drive back to two wheel drive could cause a high voltage current to the coil? I can't believe two coils would go at the same time unless it is related to some other problem. By the way, I have kept the truck in two wheel drive since replacing the last coil and it is running fine.
Thanks!
2000 Ford Expedition xlt battery saver relay clicking no start websurfer Expedition & Navigator 13 11-14-2016 03:22 PM
Trouble Shooting Challenge - Logic Help Appreciated! Grinder Man Expedition & Navigator 14 10-10-2014 10:35 AM
Custom Gauges PA F250 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-28-2013 07:35 AM
Exhausted Tugly 1999 - 2003 7.3L Power Stroke Diesel 17 09-26-2011 11:04 AM
MPG OVER HERE Rosson03 Excursion - King of SUVs 23 02-26-2011 04:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
