1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-12-2014, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Can't program new key fob - tricks?
Old 12-22-2008, 01:18 PM
biggbradwolf's Avatar
biggbradwolf
biggbradwolf is offline
This might help...
I have a 2004 F250 (4-door) and I had the darnedest time figuring this out, but if you first get in the drivers side and lock the doors, then unlock all the doors before putting the key in the ignition to perform the 8 cycles of off/on in 10 seconds (leaving the key in the "on" position on the 8th turn, the doors will lock and unlock, at which time you have 20 seconds to press any key on your fob or fobs to program them. Finally, turn the key to the off position and your key fob(s) should be programed. The dealer was of no real help on this, unfortunately. I hope this helps some folks out! Good luck!
Old 02-26-2009, 09:26 AM
Fireskott's Avatar
Fireskott
Fireskott is offline
just bought mine with no fobs at all. i cant get truck to enter programing mode either. Is it possible that an 03 wouldnt have keyless entry capabilities? f350 with all power options and leather...not a lowend vechile at all.
Old 02-26-2009, 10:37 PM
shorebird's Avatar
shorebird
shorebird is offline
From page 87 of the 2000 Expedition Owners Manual;
Programming remote transmitters
It is necessary to have all (maximum of four — original and/or new) of
your remote transmitters available prior to beginning this procedure.
To program the transmitters yourself:
² Insert a key in the ignition and
turn from OFF to ON
eight times in rapid succession
(within 10 seconds) with the
eighth turn ending in the ON
position. The doors will
lock/unlock to confirm that
programming mode has been
entered.
² Within 20 seconds, program a
remote transmitter by pressing
any button on a transmitter. The doors will lock/unlock to confirm that
the remote transmitter has been programmed. (If more than 20
seconds pass before pressing a remote transmitter button, the
programming mode will exit and the procedure will have to be
repeated.)
² Repeat the previous step to program additional remote transmitters.
The doors will lock/unlock to confirm that each remote transmitter has been programmed.
² When you have completed programming the remote transmitters, turn
the ignition to OFF or wait 20 seconds. Again the doors will
lock/unlock to confirm programming has been completed.
Same instructions for the '03 F-350
Old 02-27-2009, 08:42 AM
vettman80's Avatar
vettman80
vettman80 is offline
vettman80
had the same problem found out after much frustration that if you unhook the battery for ten minutes like when you are clearing codes then the fob programmed up first time it worked great for me
Old 05-13-2010, 01:38 AM
n2o408coupe's Avatar
n2o408coupe
n2o408coupe is offline
Thank you! This method worked like a charm!
Old 05-19-2010, 04:24 AM
jbwhit29's Avatar
jbwhit29
jbwhit29 is offline
2002 Excursion Key fob programming
Just read over some of the comments for programming the key fobs. Before you disconnect the batteries for 10min definately try getting in the vehicle, drivers side, close door then lock and unlock vehicle from inside door switch. Then proceed with the programming procedure. Worked for me. Thanks.
Old 06-23-2010, 08:15 PM
namv68's Avatar
namv68
namv68 is offline
fob programing
do i have to un hook both bats on my F350 to reset the fob programing ?
tried the locking inside the car and did it again and it worked just gotin the truck and lock and unlocked the the doors and did both fobs thanks
Old 07-01-2010, 01:13 AM
cbt02diesel's Avatar
cbt02diesel
cbt02diesel is offline
2002F250 Diesel 4Dr
I have tried all of these and the fob's initially work, but once I take the key out of the ignition they don't work. What else can I do? I really want them to work, but I don't know what else to do.
Old 07-01-2010, 03:40 PM
waldosnavi's Avatar
waldosnavi
waldosnavi is offline
not sure if this helps but my Navi had both plugs disconnected from the RKE box tucked way up in the dash. Reason for this was because it had and after market alarm that was crappy so I took it all apart, tried 4 different key fobs trying to program them and had no luck until I noticed the RKE box not plugged in. Still entered programming mode, just didn't program. Hope this helps a bit!
Old 07-11-2010, 10:00 PM
cbt02diesel
waldonsnavi is the RKE box in the fusebox? Do you know where I can find info on it?
Old 07-11-2010, 10:16 PM
waldosnavi's Avatar
waldosnavi
not sure on other models, but on my 98 Navigator, it is way up on top to the left, under the dash. Its easyer if you lay on your back on the floor board looking up with a flash light, this way it will be on your right side though (because your back words). Its bolted to the body waaaay up there, its almost impossible to see at first glance, look for a silver shinny/gray box with numbers on it. If you still cant find it I can take some pics.
Old 07-12-2010, 01:33 AM
cbt02diesel
Thanks! I will look for it.
  #28
Old 10-30-2010, 10:06 AM
01Two50's Avatar
01Two50
01Two50 is offline
turn from OFF to ON
entered.
repeated.)
This procedure just worked for my 2001 F250. Thanks
  #29
Old 11-24-2010, 08:30 AM
TruckinAL's Avatar
TruckinAL
TruckinAL is offline
Does a 97 F-150 have the key fob option ? Where is the module located ? I didn't get one with the truck but I have one from another vehicle.
  #30
Old 03-21-2012, 06:01 PM
DGMFORD's Avatar
DGMFORD
DGMFORD is offline
I was not part of this thread originally, but my FOB stopped working on my 2005 F250, what I found to work is to not run through the sequence too fast, meaning do not toggle the off/on 8 times too fast or it will not enter program mode. The book states you have 10 seconds to step through the process, 1 second per sequence worked for me perfectly.
FOB ON! <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Quick Reply: Can't program new key fob - tricks?
