veci label - Ford Truck Enthusiasts Forums
General Automotive Discussion
veci label
Old 01-23-2005, 09:52 PM
bulldog_014 bulldog_014 is offline
bulldog_014 is starting off with a positive reputation.
Question veci label
hello I'm a new 1972 ford f250 owner and need to check my timing I have a manual that tells to check the veci label to see where the timing marks need to be but I cannot find it where is it
Old 01-23-2005, 10:20 PM
FSC FSC is offline
FSC is starting off with a positive reputation.
The VECI is on the inside of the hood or on the radiator support and privides tune-up info and a vacuum diagram, if it is missing, set the timing to 8-10 degree BTDC with the vacuum hose removed and plugged and that will put you in the ballpark.
Old 01-23-2005, 10:36 PM
thank you very much
Old 01-23-2005, 10:37 PM
bulrydr_1's Avatar
bulrydr_1 bulrydr_1 is offline
bulrydr_1 is gaining momentum as a positive member of FTE.
The VECI label may also be located on the driver's side valve cover...
Old 01-24-2005, 04:03 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Your truck most likely won't have one. They were on the valve covers until 80 or 81, but only lasted about 10 years, depending on how and how often the engine was washed. Most of those foaming engine cleaners take them right off, and so do pressure washers.
Old 01-24-2005, 06:55 PM
bulrydr_1's Avatar
Quote:
This is true. Mine was on the valve cover and over the years it has worn pretty bad. I did find a replacement sticker from AutoKrafters that I'll be placing under the hood.
Anyone with a 1997 F350 7.5l can help? GuitarJesus S. California Chapter 2 06-07-2016 12:22 AM
1992 Ranger idles high in park, good with IAC disconnected 1998Ranger25L153CID Ranger & B-Series 5 09-23-2014 07:36 AM
92 F150, 300 4.9, MOD5 Speed - Flooding / VECI Label slmartin 1987 - 1996 F150 & Larger F-Series Trucks 4 04-23-2008 05:30 PM
98 Ranger 2.5L Spark Knock, What's wrong? 1998Ranger25L153CID Ranger & B-Series 2 10-27-2006 07:29 PM
Motorcraft 2150 Specs IowaTower Fuel Injection, Carburetion & Fuel System 0 01-17-2006 08:20 AM
Tags
1977, 2008, 81, car, cover, diesel, excursion, f150, ford, label, labels, schematic, taurus, trucks, valve, veci
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
