check engine light...
If it's running rich after being warmed up it could be the ECT went south, cheapest and easiest by far and fairly likely. Fuel pressure regulator could be stuck. Or if it's only rich at idle, the vacuum line to the fuel pressure regulator could have come off. If it ONLY does it when cold and QUITs when it's warmed up, the MAF could be bad or disconnected. Wiggle the connectors to everything before condemning them. A little moisture can screw up a connector when it freezes and expands.
Let us know when it happened. Before then engine warmed up, after the engine warmed up, or both. Only at idle, only at off idle or both? When did the light first come on?
Yeah, I was able to get someone to look at it yesterday. The code was a misfire on #8 which caused the rough and rich condition. Seems this nast blizzard drove snow right up in to the engine compartment resulting in water down to the coil and plug. Hmmm. Any thoughts on preventing this short of moving south. Those coils an plugs aren't cheap. Thanks. AF
Frankiec#1
02-15-2021 09:47 AM
abyars111
11-12-2012 09:18 AM
