I know there is a spot to to tie into it under the driver's side battery but i don't remember what wire it is but superlift's tru speed sensor uses the same wire. go to superlift's website and look under "products" at the bottom of the list is installation instructions then select truspeed sensor and it says exactly where and what wire it is.
The VSS wire is found under the fuse box at the drivers engine compartment. It is
Pin #58 and is a Grey/Black wire. The plug is numbered so just count the pins until you find it. Hope this helps!
