F250 Superduty 2WD Wheel Bearings
Alright...the last time i repalced my front rotors on my 2wd superduty, i packed the front bearings, replaced the bearing races and wheel seals and when i torqued them, i ran the the nut snug...probally to about 50lbs of torque, backed off till loose, the back to about 20lbs (roughly). So my two questions are 1) how close was i on the seating/ torquing specs, and 2) how often should the front bearings be re-packed? Currently i have about 25,000 since i replaced the rotors.
Thanks for the replys!
FLYINFORD
FLYINFORD
I'm in the middle of doing my ball joints and bearings tonight.
I didn't have that large a socket for my lil torque wrench - so i did a test, with the lil one set at 18 INCH.lb. It's as tight I can turn a large socket with my bare hand and greasy fingers. Clean hands got me between 20 and 21 INCH.lb
Hope this helps. :-)
TampabayBill
10-16-2016 05:53 PM
jayro88
06-12-2016 05:13 PM
J.McConnell
13
04-21-2009 12:19 PM
