installing new glow plugs - Ford Truck Enthusiasts Forums
Old 01-21-2005, 10:48 PM
mikeAK mikeAK is offline
mikeAK is starting off with a positive reputation.
How does one install the glow plugs in the 97 E350 PSD?
The manual says to remove the valve cover, but the link on the CD doesn't get me to the right picture.
I bought the autolite 1111, does it matter which plugs are used?
Thanks!
Old 01-21-2005, 11:23 PM
believer45 believer45 is offline
believer45 is starting off with a positive reputation.
First off, yes it does make a difference. I have run across many folks who have had problems with the Autolite glow plugs either swelling over time so you cannot get them out if replacement comes up (a pain but not a catastrophe) or breaking off inside the engine with the expected major internal damage. I would take them back and get the factory units. If you have AutoZone in your area they sell the Motorcraft (made by Beru) in Motorcraft part bags with the Ford part number on them for under $10 each. Their part number is ZD-11.
As for the installation, CLICK HERE to go to an excellent how to article on the glow plug system by Carpentractor.
Hope these help out - Carpentractor's article helped me a lot.
Old 01-22-2005, 12:54 AM
obmf2 obmf2 is offline
obmf2 is starting off with a positive reputation.
Do NOT use the autolite glow plugs! I had four break off while removing. I spent hours removing three of of the broken ones from the top side. The fourth one broke and left the element in the head. Two dealers said the head would have to be removed. Instead i was able to remove it through the fuel injector hole. I dont ever want to do that job again. Please use the motorcraft glow plugs!!!!!!!!
Old 01-23-2005, 01:09 AM
I was wondering if I could still use the autolite 1111 glow plugs if I used some sort of anti-sieze stuff?
So if I do use the motorcraft plugs, has anyone had trouble with them.
regards
Old 01-23-2005, 02:27 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Anti sieze has nothing to do with it, it's not the threads on the head that are the problem it's the element itself as it swells up with repeated heating then when you try, and pull it out it doesn't fit through the hole, and breaks off leaving the tip sitting on top of the piston you might as well drop gravel into your intake (they will also just burn off and drop down also or so I have heard)
Old 01-23-2005, 03:26 PM
regards
I still would not run the Autolites. If you cannot return them chalk it up to a lesson learned and throw them as far from your truck as you can, use them as small paperweights but I strongly suggest you DO NOT install them in your engine. You may be one of the many who have no trouble with them or sell of the truck before failure but the percentage of problems with Autolites as compared to Motorcraft is exponentially higher.
As for Motorcraft, I have not had a problem with mine and I have not run across anyone else who has in four and a half years on 9+ forums that deal with diesels, Fords, towing and the like.
You can do as you wish.
Dave / Believer45
Old 01-23-2005, 05:10 PM
rus7755 rus7755 is offline
rus7755 is starting off with a positive reputation.
I have the same problem with 3 glow plugs on my '97 F250 Powerstroke (206,000 miles). My mechanic is ready to remove both cylinder heads tomorrow due to siezed glow plug electrodes. He has tried (for several days) penetrating oil with no results. I am concerned at this point about debris from the electrode being left inside. Is it best to remove the heads now or should we keep on trying the penetrating oil method? If the heads are removed, what gotcha's are there that we should look for? How mush should head removal cost on a powerstroke?
Any advice would be appreciated.
Thanks,
rus7755
Old 01-24-2005, 07:42 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Welcome Mark, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE ..
Old 10-02-2012, 08:45 AM
hetmaster hetmaster is offline
hetmaster is starting off with a positive reputation.
I have a 1992 F350 with the 7.3. Would the articals you have posted help me replace my glow plugs too?
Old 10-02-2012, 11:04 AM
KelVarnson KelVarnson is offline
KelVarnson is a name known to allKelVarnson is a name known to allKelVarnson is a name known to allKelVarnson is a name known to allKelVarnson is a name known to allKelVarnson is a name known to all
Quote:
May I ask why you are replacing the original ones? Have you verified they are bad?
They're just a resistor, not much to go wrong (aside from the Autolite horror stories), either they work, or they don't.
Old 10-02-2012, 12:15 PM
lartross's Avatar
lartross lartross is offline
lartross is gaining momentum as a positive member of FTE.
hetmaster, you have an idi. Go to the idi forum and they will have instructions for gp replacement [much easier than powerstroke]
After you upgraded your alternator... did your glow plugs fail more often? Y2KW57 1999 - 2003 7.3L Power Stroke Diesel 59 01-29-2017 01:44 PM
f 350 glow plug light colokerrie 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-09-2012 04:49 PM
Glow plug amp draw guitarpicr 1999 - 2003 7.3L Power Stroke Diesel 7 05-20-2011 07:59 AM
glow plug relay theory of operation and oem p/n tpolley Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 05-11-2009 10:29 PM
I change glow plugs still hard to start adamzelazowski Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 59 05-11-2009 04:16 AM
Tags
1999, 73, 73l, autolite, cost, f250, glow, harness, install, installing, internal, motorcraft, obmf2, plug, plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
