how long to sandblast?
What kind of equipment do you have? How many coats of paint do you think are on your truck? Time can really vary. Real good equipment can make short work of light rust and decades old lacquer. Two stage compressor and a pressurized blaster will do it in a few hours perhaps. It could be done faster with professional equipment, but you risk damaging the metal. Uncatalyzed enamels (soft) and an air compressor that can't keep up can make it quite time consuming.
I'm a DIY guy, though my equipment really extended the blasting time.
Originally Posted by Madathlon
Just a thought here, But My Chiltons Crash Book on a 2003 F150 gives me 22.5 hrs to strip a complete Cab for repainting.. @ $40 a hr that would be $900.00
I started to do a project like this on my own (it was a mustang) and I ended up having a sandblasting company do it all over for me. I didn't have to burn out my compressor, clean up the mess, spend several days doing it, breath all the dust, buy the protective gear, buy and hump all that grit, and this company was an industrial blaster. They had the pressure and volume to do it right, They also primed the bare metal.
I guess you are asking how long it would take youself to do it. Think of a time and then double it atleast.
My 2 cents
My 2 cents
if i do it myself it will be at school. there is a 90lb capacity pressure pot blaster that has never been used. the school got it becaus eme and another guy in my class have been blasting alot of stuff. so we have a pretty heavy duty compressor. i'll be doing it outside so i wont really have to worry about clean up....and i really need to do my hood and doors as well....how much sand do you all think it will take? oh and the only paint that is still on it is on the inside of the doors. jambs and back of the cab. the rest is surface rust
Blast a door. Then you will have a very good idea how long it will take with your equipment. Surface rust will blast off quickly. Heavy rust will not.
I've blasted every inch of several vehicles. An entire 31 Chevy sedan, inside and out in about 4 hours with the right equipment I rented. (Ingersol Rand 4 cylinder compressor).
My truck took days with my single stage compressor. Frame only took an hour or so because it was not rusty. Inside of cab was quick too. Exterior sheetmetal had a lot of soft enamel on it and went VERY slow. Easily an hour per panel.
Sand or abrasive grit is not the proper media for paint blasting. It eats away metal as well as paint and peen hardens the surface making body work difficult. A blaster that truly knows what they are doing will use a soft media like walnut shells and plastic to remove paint. You DEFINITELY don't want to use play sand unless you have a filtered forced air hood, Silicosis KILLS! Paint stripper is a much better alternative with spot blasting to remove rust if you must do it yourself.
Nixer
Sometimes paint stripper is a great solution. Though I recommend you make sure you don't have any stripper on your hands before you use the restroom. Double check when you remove your gloves, even a little drop is most unpleasant.
Seriously, I have used stripper a number of times. Sometimes it's the cats meow. Then the next time you hit some good oven baked factory primer and you got as mess you wish you had blasted. Can you say 8 coats of stripper and putty knife the entire car. There is no perfect solution for every situation. Stripper is worthless on rust. I've seen some pros use the four guys on a DA sander method to strip. That has drawbacks as well.
Anybody that thinks they have the perfect single lowbuck solution that is optimum in every situation is having a fantasy.
