Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-21-2005, 05:43 PM
vekrause vekrause is offline
Garage is empty, add now
vekrause is starting off with a positive reputation.
Question 2.3 timing belt removal
'89 2.3 in a '91 ranger
Trying to replace the timing belt since I have everything torn apart for a new head gasket. Can't seem to get it removed. The bolt holding the balancer/hub won't budge, even tried an impact on it. Can't get the hub off to get the guide off to get the belt off. Any suggestions?
Thanks,
Vince Krause
  #2 (permalink)
Old 01-21-2005, 07:22 PM
Chris_ce's Avatar
Chris_ce Chris_ce is offline
Chris_ce is starting off with a positive reputation.
Well this is what I done but don't know if you want to try it. I disabled the coil put a breaker bar on the bolt and bumped the starter and it broke it loose like it was nothing. Make sure the bar is resting on the ground before you bump the engine.
Not held liable for injures.LOL
__________________
1990 F350 DRW 460 E4OD
1978 Bronco custom 351m C6
1996 f-150 ext cab 4x4 eb 5.0 35/12.50/15 6in superlift
Indiana Chapter Leader
  #3 (permalink)
Old 01-21-2005, 09:19 PM
Thanks, that might be the "when all else fails" plan...
Tags
1996, 23, 91, belt, change, ford, ranger, removal, ripped, timing, timming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
