My Friend has a 1997 PSD and wants to change trhe fuel filter, but the cap
must have been overtightened since it's impossible to break loose. Someone alredy tried to loosen it and just manged to break off some of the tabs in the
process. Does anyone know if they make a special wrench or tool to loosen the top without ruining it? Thanks for any advice I can get
A big oil filter wrench is good. I've also seen people take a piece of big PVC pipe and cut notches in it for the tabs - that way you're pressing on all 4 tabs at once and are less likely to break any. (You drill a hole farther up the pipe to add a T-handle)
Ok... on my last post if you click on the http://www.cyclonediesel.com/ford.htm link you get redirected to Motorhaven. I like Motorhaven, but they don't sell this fuel filter wrench, so the redirect sucks. Copy and paste to go to cyclone diesel.
Thanks for the help guys, I think she's going to order the wrench from Cyclone. I found out the clown the broke the tabs off was using the screwdriver method, so we were a little leery of trying it again.
Thanks for the help guys. I think she's going to order the wrench from Cyclone.
I found out the idiot that broke the tabs off was using the screwdriver method, so we were a little leery of trying it again.
we were a little leery about trying it again.
