2000 ford ranger abs light no speedometer
Hi guys quick question. I had all of these things happen to me tonight on the way home from work. My ABS light came on, and about 20 miles later the truck would start shifting very hard and reving up like it would not change gears. And then the spedometer went dead no reading what so ever. I was going to take it in to the transmission shop tomorrow to get cheecked out. I decided to get on here and see what it could be. Does this sound like the the same sensor?
Thanks,
Bryan
Thanks,
Bryan
thanks guys. I had the same problem when I left for work this morning. ABS Light on. No speedometer. Stopped at a local parts house and got the sensor for $7.00. Installed it tonight. Worked like a champ! You guys are a life saver. I hate to think what it would have cost me to take this to a shop.
same probleme
i have a 2000 ford ranger 2.5L 2WD and i got it scanned and it said i need a new VSS but autozone sold me the part and its in the transmission and everyone else said its in the differential, i looked at the differential and i see no place where it would go. help is greatly thanked.
the napa price is one of the best I have found.....discount auto, autozone and pep boys are more than 2x the price.
There will be a plug on top of the center section of your rear axle. Its right up on top and the only thing with wires going to it. Kinda hard to see until you are under the truck on your back.
thanks ill check it out but this is the part they sold me
http://www.autozone.com/R,APP518912/...ductDetail.htm
is that the part that goes in the place your talking about?
I have a 1999 Ford Ranger Extended Cab 4X4 Manual Transmission. My Speedo quit working and the ABS light and now the Service Engine Light are on. Which sensor is the correct one?
http://www.napaonline.com/MasterPage...+Sensor+-+Rear
http://www.napaonline.com/MasterPage...rential+Sensor
