Fenderwell Headers on 79 Bronco?
Has anybody installed the Hedman fenderwell exit headers on a 79 or 78 Bronco? I'm wondering what kind of modifications are needed to fit them out over the frame. Will I need to take out the splash guards? What about shocks, coils spring, and brake line clearances?
I'm curious because right now I have chassis exit headers and dual exhaust running the length of the truck on the passenger side. It works but the bends are a mess and the exhaust is below frame level in a couple of spots. So, I was thinking that fenderwell exit headers would make it easy to run a nice clean line down each side and turn it out in front of the back tires somehere. I'd appreciate hearing your thoughts on this one. I know there must be a bunch of you guys that have done this to your trucks. Thanks!
I've seen pictures of these things on, but have no real world knowledge of them..so take this advice for what you will.
None of the vehicles have had the splash guards. Looks like if you kept them, they'd turn liquid and smelly pretty quick. Some people have had problems with tires rubbing them on a full turn, but if youre not running wide tires, you should be OK.
On my '79, my tires (12.5" wide) rub on the radius arms on a full turn, so I know that headers of that nature would warm up my tires.
alone and unafraid
21
02-20-2019 05:25 PM
COFLHTK
02-08-2016 10:49 PM
The Freak
23
11-02-2009 07:34 PM
somethingclever
05-13-2009 10:35 AM
