Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-20-2005, 03:34 PM
reamer's Avatar
reamer reamer is offline
reamer is starting off with a positive reputation.
Any Known Way to replace.......
The complete rear Differential to something more modern and highway friendly ('74 F-350 dual rear) in to a '48 F-5
Yet keep the five bolt rims and tires?
Thanks
Reamer
  #2 (permalink)
Old 01-20-2005, 03:38 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack is gaining momentum as a positive member of FTE. Randy Jack is gaining momentum as a positive member of FTE.
Reamer - One way is to have the axle flanges of the new rear end drilled out (by a machine shop) for your hole pattern. Use the F5 wheels studs and mount your rims/tires. Voila!
__________________
Randy Jack
56 F100 Street Rod Daily Driver
Growing OLD is mandatory. Growing UP is optional.
Inside every old guy is a younger guy wondering what the heck happened.
  #3 (permalink)
Old 01-20-2005, 06:33 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders is starting off with a positive reputation.
Randy Jack
You sure it's going to be that easy? Unless I misunderstood, he's talking about converting an 8 bolt dually hub to 5 lug pattern. Bolt circle is going to have to be near identical to even have a chance.
__________________
'fenders
53 F100
"All Ford" Volare Truck
  #4 (permalink)
Old 01-20-2005, 07:24 PM
reamer's Avatar
yep, this is the tough part. Not sure what I'll do.
  #5 (permalink)
Old 01-20-2005, 07:43 PM
Earl's Avatar
Earl Earl is offline
1956 Ford F-250
Earl has a good reputation on FTE. Earl has a good reputation on FTE. Earl has a good reputation on FTE.
I know that F-5 is a heavier truck, but if you aren't planning on using the full payload, could you get the ever-popular Ford 9" under there without too much modification?
__________________
George
Truck restoration - does the fun ever start?
See my 1956 F-250 in progress at Earl's World
FTE Guidelines
  #6 (permalink)
Old 01-20-2005, 08:00 PM
dmptrkr dmptrkr is offline
dmptrkr is starting off with a positive reputation.
If I were considering changing out the rear axle I think I would be looking for a way to match the bolt pattern by changing the front too and get rid of the split rims. Excellent topic for a thread. There's a lot of information in the archives about axle swaps for lighter trucks but I don't recall ever seeing anything about the bigger ones.
__________________
Craig
50 F-5 with 47 Heil dump box 2 1/2 yrd
48 F-5 with Gar "Wood" dump box 1 1/2 yrd
97 F-350 Powerstroke Dually flatbed sleeper cab
  #7 (permalink)
Old 01-21-2005, 02:16 PM
reamer's Avatar
My F-5 does not have split rims. (I think) there is no removable steel ring around them.
I'm wondering, I have a dualy rear end form a '74 F-350.This one has the "normal" Ford 8-bolt pattern and rims.
I was thinking, where can I find out if I can get Ford 8-bolt dually bud rims that will fit my existing '48 Ford 7.50 x 20 tires?
Reamer
  #8 (permalink)
Old 01-22-2005, 09:15 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has a good reputation on FTE. bobj49f2 has a good reputation on FTE.
dmptrkr and I have been thinking about the wheel problem for about a year. I agree with him, if you can change both the front and rear hubs to accept modern eight hole hubs I would go that route, it will be a lot easier finding rims and tires. Finding five hole rims that aren't split rims are next to impossible and if you go with the 22in tubeless, like the ones on my F-4, it is hard finding tires that will fit. The Izuzu truck has 16" rims with a matching five bolt pattern but the rims are smaller which makes the overall height about 2 or three inches lower. I am thinking about going with the Izuzu 0n my F-4 because it is not much larger than my F-2 which has 16" wheels, I don't know how they would look on the larger F-5 or 6s.
BTW, I am sure you have split rims. They don't have a retaining ring on the outside, they are made up of two halves that twist apart. These have corresponding knotches that have to be spun 180 degree during assembley and they have to be in near perfect condition, no rust or bends, to make sure they stay together. Most tire places won't touch these, they like them less than the snap ring type.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup/48 F-1 panel truck
48/51 F-4 flatbed (2 in 1)/49 8N tractor
www.fatfenderedtrucks.com
  #9 (permalink)
Old 01-22-2005, 07:15 PM
reamer's Avatar
dmptrkr has a good point.
If ya covert the rear to 8-bolt and not the front, if a flat comes your way on the front, ya cant use a rear up fron cause the rear is now eight bolt.
Izuzu has a five bolt 16"? are you talking the small pickups and suv's or the big truck fleet?
Will they fit on the F-5 axles?
Option 2, anyone out there know of a company that may have a ring & pinion set in the low 5's for ratio, (better than the 6:66 in there now) that will fit in the stock rearend of the F-5. (this is the type where the right and left sides bolt togeather.
Thanks
Reamer
  #10 (permalink)
Old 01-22-2005, 08:05 PM
bobj49f2's Avatar
I got mixed up, I meant Mitsubishi Fuso , all the rice burners are the same to me. These are comercial size trucks, the one with the 5 lug 16" wheels is the smallest model, I think.
__________________
Tags
16 , budd , fuso , lug , pattern , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
