95 ford ranger disabling the chime - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-20-2005, 01:18 PM
Dclawson Dclawson is offline
Dclawson is starting off with a positive reputation.
Hi, I asked help before on my chime problem-someone said use wd40. I really would like to know which wire to cut. My truck is possessed, it keeps ringing on and off. I would appreciate anyones input. Thanks,Dave
Old 01-20-2005, 06:27 PM
rangerdog rangerdog is offline
rangerdog is starting off with a positive reputation.
Just follow your ear and un-plug the little black box that is making the noise.
Old 01-26-2005, 04:35 PM
samich samich is offline
samich is starting off with a positive reputation.
The "box" is behind the radio on the drivers side... unfortunately unplugging it also dissables the windshield wipers and interior lights.
Old 01-27-2005, 09:43 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Purposely and willfully destroy the chime itself?? (If ya cant unplug it) I had a friend pay me a few bux jus to ..."disable" his in the Chebby S-10
Old 01-27-2005, 11:14 PM
da'Moose da'Moose is offline
da'Moose is starting off with a positive reputation.
In 95’ Ford was still using the buzz box. I removed it from my F-150 and my Ranger, with no problems with any other systems.
Da’Moose
Old 01-28-2005, 12:18 AM
Donald Rohret Donald Rohret is offline
Donald Rohret is starting off with a positive reputation.
Sorry, I don't know which wire to cut to disable the chime. I also have a '95 Ranger and was bothered by my chime sometimes sounding off when I exited the truck and sometimes it wouldn't. Some kind soul, who was aware of my problem, inquired if I had an after market radio installed. I did indeed. Apparently the GEM circuit was screwed up when they installed it. I found if I always leave my radio turned on, when I turn off the ignition key, the alarm doesn't chime when I exit my truck. Just a thought.
Old 01-28-2005, 06:30 PM
pic498 pic498 is offline
pic498 is starting off with a positive reputation.
I Know How To Fix It!!!
my 95 did the same thing... chime would ring forever after i shut the door and was going down the road, and the interior light would stay on too. So what i did was got into that black box, removed it, then just broke off the siren. then i put it back in. the light stayed on though. so then my friend that had a 96 said to spray WD40 in the door jamb, so i did and the light stayed off. Now i wish i would've just used the wd-40 so i'd stop leaving my headlights on (you know--the headlight warning chime). but yeah, if the wd didn't work--break it off.
Old 09-28-2005, 01:38 PM
RickPlmr RickPlmr is offline
RickPlmr is starting off with a positive reputation.
Question How to disable the alarm horn honk?
Hopefully this isn't too off topic, but is there also a way to disable the horn from honking when the alarm is set (i.e. when you press the lock button twice on the key fob)?
Old 09-28-2005, 01:56 PM
Gibber 1 Gibber 1 is offline
Gibber 1 is starting off with a positive reputation.
The only way to disable the chime in a newer Ranger (and I'm not sure when Ford went to the circuit board type chime/windows/doors/etc.) is to take out the radio, remove the board from its case and very carefully unsolder the chime from the board. It can be done!! --- and after doing it, it's nice not having to listen to the stupid thing when you're trying to listen to the radio with the doors open!!
Door Chime bennya1 1999 to 2016 Super Duty 11 06-09-2016 09:05 AM
Annoying key chime Neil Sandall 6.0L Power Stroke Diesel 5 02-12-2016 07:40 PM
Door chime bigcountry1009 1999 to 2016 Super Duty 8 11-13-2014 08:07 AM
Chime Hanlon50 2009 - 2014 F150 3 09-15-2013 07:30 PM
how to disconnecting door chime Hotest Rod Electrical Systems/Wiring 14 02-19-2003 12:31 AM
Tags
94, 95, 96, 97, chim, chime, chimes, disable, disavle, disengage, door, ford, ignition, ranger, remove, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
