Dana 70 Lug bolts
You have to pull the hub to get at the studs keep in mind the studs hold the brake drum onto the hub. You drive them out and tap the new ones in then take a lug nut and a spacer under it (old deep socket turned upside down) to seat the studs in the hub.
Its a piece of cake changing the studs the biggest part is pulling the lock nuts off and bearings out and changing the oil seal that you can never save.
mattjensen
04-24-2009 04:28 PM
BlueOvalBud
02-24-2007 08:36 PM
