Keyless remote - Disabling alarm "chirp"
Not sure if this is the right forum for this but does anyone know if there is some way to turn off the "chirp" of the horn when the alarm is set on an '03 F350?
The chirp is way too loud and everyone around thinks I'm honking at them when I hit the keyless remote alarm button. I still want to be able to set the alarm, I just don't want to hear the chirp (or at least quieten it down some). I also don't want to disconnect my horns to avoid it.......for obvious reasons.
Thanks for any help!
Originally Posted by fatherheart3
How Do I Program More Than One Remote For My F-350 1999 Dually..can It Be Done.i Turn The Switch 5 Times But Won't Prograqm More Than One..help/..
Thanks
Thanks
sorry my friend,`but i was not hijacking anything..i can't get my text to write on a new post..there is no reason to be accused of being rude since there is plenty of room to answer your question..i did ask for help, not correction.i apoligize if i offended you..this is a great forum and i find most people very nice..again forgive me. thanks fatherheart3
I have an '02 and the '03 may be different, but when I hit the remote lock button once, it locks the door AND sets the alarm. The second push is if I WANT an audible confirmation, I don't have to push it a second time to set the alarm. Again, this could have changed on the '03, I'm not sure.
Randy
Randy
Randy
Randy
dragula-
I'm not aware of ANY factory alarm system on Super-Dutys. But there's an easy way to test for one: Start truck, roll down driver's window. Shut truck off, get out, close door and then lock with remote. Wait 60 seconds, reach in thru open window and open door from inside. If horn starts honking, you've got an alarm.
fatherheart3-
you have to turn the key on and off at least 8 times (maybe 10) to program an additional remote. Just keep turning the vehicle on and off till the doors lock and unlock, then you can program your extra remote. But you have to do all of them at that time, even the previously-programmed ones.
fatherheart3-
Originally Posted by 1956MarkII
dragula-
fatherheart3-
fatherheart3-
Originally Posted by marspec
...I just figured it was still a feature you had when you ordered your SD with everything but the kitchen sink and the window sticker says it has the advance security group.
Well, Jeff I guess you're right. I don't have an alarm at all. I tried as you said and the alarm never went off. It obviously doesn't have one. I thought it was like my other Chevy truck and my wife's GMC Jimmy, both of which set the alarm by pressing the lock button twice.
You would think that a truck with an MSRP of over $50k (an F350 King Ranch) would have a real alarm. It seems kind of ridiculous to have the audible "chirp" at all and especially to have the panic button on the remote and to not have an actual security alarm.
Well, I guess I don't have to worry about the noisy chirp now since pushing the lock button twice does nothing more than pushing once (other than make it chirp). Guess I'll be looking for an aftermarket alarm now.
Thanks for the help.
Does your truck have a blinking LED light? (Likely located near driver’s footwall) My Ford perimeter alarm chirps during disarm and arm. Your alarm may not have gone off when you opened the door if it was in “valet mode”. In valet mode the alarm still chirps but is not fully engaged. To turn off valet mode, press in the LED light, which is also the valet switch. Now the alarm should chirp once on disarm and twice on arm. This is how my ford perimeter alarm operates onmy 2000 Mercury Sedan and Mustang GT... however it may be different with your super duty. <o =""></o>
Good Luck,<o =""></o>
Joe<o =""></o>
Joe<o =""></o>
noyield
10-07-2003 07:10 AM
