Keyless remote - Disabling alarm "chirp" - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-19-2005, 08:53 PM
dragula dragula is offline
dragula is starting off with a positive reputation.
Not sure if this is the right forum for this but does anyone know if there is some way to turn off the "chirp" of the horn when the alarm is set on an '03 F350?
The chirp is way too loud and everyone around thinks I'm honking at them when I hit the keyless remote alarm button. I still want to be able to set the alarm, I just don't want to hear the chirp (or at least quieten it down some). I also don't want to disconnect my horns to avoid it.......for obvious reasons.
Thanks for any help!
Old 01-19-2005, 11:48 PM
JFWalker JFWalker is offline
JFWalker is starting off with a positive reputation.
Mine only chirps when I set the alarm twice.
Old 01-19-2005, 11:55 PM
fatherheart3 fatherheart3 is offline
fatherheart3 is starting off with a positive reputation.
How Do I Program More Than One Remote For My F-350 1999 Dually..can It Be Done.i Turn The Switch 5 Times But Won't Prograqm More Than One..help/..
Thanks
Old 01-20-2005, 09:24 AM
jlstorm jlstorm is offline
jlstorm is starting off with a positive reputation.
Quote:
Thanks
Fatherheart3, You may want to start your own post for this question. It's generally considered rather rude to hijack someone elses post by posting your own question, especially if the answer to your question won't help answer theirs.
Old 01-20-2005, 12:13 PM
sorry my friend,`but i was not hijacking anything..i can't get my text to write on a new post..there is no reason to be accused of being rude since there is plenty of room to answer your question..i did ask for help, not correction.i apoligize if i offended you..this is a great forum and i find most people very nice..again forgive me. thanks fatherheart3
Old 01-20-2005, 06:48 PM
Quote:
JF,
When I push the button once on my remote, it only locks the doors....it doesn't set the alarm. Then, I have to push the button a second time to set the alarm and that's when it chirps.
Old 01-20-2005, 06:53 PM
RUNVS's Avatar
RUNVS RUNVS is offline
RUNVS has a good reputation on FTE.RUNVS has a good reputation on FTE.
I have an '02 and the '03 may be different, but when I hit the remote lock button once, it locks the door AND sets the alarm. The second push is if I WANT an audible confirmation, I don't have to push it a second time to set the alarm. Again, this could have changed on the '03, I'm not sure.
Randy
Old 01-20-2005, 09:27 PM
Quote:
Randy
Well, maybe mine does too after all. I'll have to doublecheck it somehow tomorrow. I'll post back with results.
Old 01-21-2005, 11:09 AM
1956MarkII 1956MarkII is offline
1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.
dragula-
I'm not aware of ANY factory alarm system on Super-Dutys. But there's an easy way to test for one: Start truck, roll down driver's window. Shut truck off, get out, close door and then lock with remote. Wait 60 seconds, reach in thru open window and open door from inside. If horn starts honking, you've got an alarm.
fatherheart3-
you have to turn the key on and off at least 8 times (maybe 10) to program an additional remote. Just keep turning the vehicle on and off till the doors lock and unlock, then you can program your extra remote. But you have to do all of them at that time, even the previously-programmed ones.
Old 01-21-2005, 01:17 PM
marspec marspec is offline
marspec is starting off with a positive reputation.
Quote:
Originally Posted by 1956MarkII
dragula-
fatherheart3-
Is this another Ford Decont??? I haven't tried it on my '05 but on my '95 I woke up the whole campground when I found out at 10PM I had left a window open and reached thru it to unlock the door. I just figured it was still a feature you had when you ordered your SD with everything but the kitchen sink and the window sticker says it has the advance security group.
Old 01-21-2005, 01:33 PM
Quote:
Originally Posted by marspec
...I just figured it was still a feature you had when you ordered your SD with everything but the kitchen sink and the window sticker says it has the advance security group.
You'd think that the "Advanced Security Group" would include some sort of anti-theft system wouldn't you? Then again, you'd think that "all-terrain" tires would actually be......oh, never mind.
Old 01-21-2005, 06:09 PM
Well, Jeff I guess you're right. I don't have an alarm at all. I tried as you said and the alarm never went off. It obviously doesn't have one. I thought it was like my other Chevy truck and my wife's GMC Jimmy, both of which set the alarm by pressing the lock button twice.
You would think that a truck with an MSRP of over $50k (an F350 King Ranch) would have a real alarm. It seems kind of ridiculous to have the audible "chirp" at all and especially to have the panic button on the remote and to not have an actual security alarm.
Well, I guess I don't have to worry about the noisy chirp now since pushing the lock button twice does nothing more than pushing once (other than make it chirp). Guess I'll be looking for an aftermarket alarm now.
Thanks for the help.
Old 01-24-2005, 08:37 PM
rollinXplorer rollinXplorer is offline
rollinXplorer is starting off with a positive reputation.
Does your truck have a blinking LED light? (Likely located near driver’s footwall) My Ford perimeter alarm chirps during disarm and arm. Your alarm may not have gone off when you opened the door if it was in “valet mode”. In valet mode the alarm still chirps but is not fully engaged. To turn off valet mode, press in the LED light, which is also the valet switch. Now the alarm should chirp once on disarm and twice on arm. This is how my ford perimeter alarm operates onmy 2000 Mercury Sedan and Mustang GT... however it may be different with your super duty. <o =""></o>
Good Luck,<o =""></o>
Joe<o =""></o>
Old 01-24-2005, 09:23 PM
SummerWind SummerWind is offline
SummerWind is starting off with a positive reputation.
Quote:
Well, there is one other benefit of pushing the lock button twice. On the second press, as you've noticed, you get an audible confirmation that all is well. However, had all NOT been well, such as one of the doors ajar and otherwise unoticed by, you would get a fast double-chirp on the second push of the lock button, letting you know that all is not well, and that you should check your doors. In this hypothetical example, without the second push of the lock button, you would be unaware of your security breach. Try it, and you'll see.
How to program your 2010 to not shut down when opening door after remote start Kevgsp 2009 - 2014 F150 20 11-25-2014 08:39 AM
Remote start/alarm Now what?? jaym69 2004 - 2008 F150 10 03-31-2008 07:21 PM
how to tone down the alarm chirps expy98 Excursion - King of SUVs 3 02-09-2007 01:39 PM
2005 F-150 factory alarm question. chowder 2004 - 2008 F150 23 11-25-2005 09:03 AM
F250 keyless entry mikewrt 1999 to 2016 Super Duty 10 09-09-2004 10:48 PM
Tags
2000, alarm, arm, chirp, chirps, confirmation, disable, disarm, entry, f150, f250, factory, ford, keyless, mustang, remote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
