disable seat belt alarm - Ford Truck Enthusiasts Forums
Old 01-19-2005, 03:43 PM
cam5540 cam5540 is offline
cam5540 is starting off with a positive reputation.
does any one no how to disable the seatbelt alarm on a 2004 f-150 heritage??
Old 01-19-2005, 07:38 PM
ViperFX4 ViperFX4 is offline
ViperFX4 is starting off with a positive reputation.
Its in the owners manula under belt minder I think its called.
ViperFX4
Old 01-19-2005, 08:37 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL BatteriesNotINCL is offline
BatteriesNotINCL is starting off with a positive reputation.
Post In & Out
If it is like my truck 04FX4 (scab) you must:
  • turn the key to the on position without starting
  • wait for the airbag light to turn off (1 min but seems long)
  • In under 90 sec. buckle and unbuckle your seat belts 8 times
  • The air bag light will flash 3 times then buckle and unbuckle once more to complete the process
  • the air bag light will flash one more time to confirm action
This was in another posting of the same title which is in this very forum. I may be wrong and I am not taking credit for this discovery. I would look for it if you have any problems.
Old 01-20-2005, 08:41 AM
do i have to run around the vehicle 3 times after that? just kidding. thanks for the info, i'll let you know how it turns out
Old 01-20-2005, 09:54 AM
texasshooter texasshooter is offline
texasshooter is starting off with a positive reputation.
Does disarming the seatbelt alarm effect the passenger air bags? Just curious.
Old 01-20-2005, 05:02 PM
jperea's Avatar
jperea jperea is offline
jperea is starting off with a positive reputation.
Quote:
NOPE!!!!!!!!
Old 01-20-2005, 05:06 PM
OK thanks for the info.
Old 01-20-2005, 05:43 PM
HammerFX4 HammerFX4 is offline
HammerFX4 is starting off with a positive reputation.
Along with those instructions you have to put your emerg brake on and it`s nine times to buckle and unbuckle.Page 117 or 118 in the book.
Jim........
Old 01-21-2005, 09:58 AM
I completely thought you guys were screwing with me. but it does work, for the heritage its a little different (page 80 of the manual) . thanks for the help. bing, bing, bing, bing, bing
Old 01-22-2005, 11:22 AM
shock1wsu shock1wsu is offline
shock1wsu is starting off with a positive reputation.
I've found the easiest way to turn off the "ding" is to:
Put key into the ignition -
Actually start the engine -
Fasten the seatbelt -
Put truck in drive -
Start driving - amazing - no "ding"
You've just successfully disengaged the alarm without wasting your Saturday morning!!
Old 01-22-2005, 05:29 PM
05ontheway 05ontheway is offline
05ontheway is starting off with a positive reputation.
OR, you can do like me and turn the "beltminder" on and off for both the drivers seat and passengers seat, (repeatedly) and still not get the seat belt chime to sut off. I know I must be doing it right because I can get the single burst of air bag icon flashes (thats off) as well as the double bust of flases (thats on), but no matter what that lovely chime continues to do its thing! Take your choice waste your time or not!
Old 01-30-2005, 03:27 AM
XLTBryan XLTBryan is offline
XLTBryan is starting off with a positive reputation.
Auto Locks
A little off topic but similar.. Does anyone know how to disable the doors from auto locking?
XLTBryan
Old 02-01-2005, 04:37 PM
F150lady F150lady is offline
F150lady is starting off with a positive reputation.
Nice response, very insightful answer, if you can't say something helpful then shut the #@&! up.
Old 02-02-2005, 06:47 AM
Smoove's Avatar
Smoove Smoove is offline
Smoove is starting off with a positive reputation.
Quote:
Me thinks F150Lady might need a name change to F150CrossDressingTruckDriver
Old 02-21-2005, 12:18 AM
fordborn's Avatar
fordborn fordborn is offline
fordborn has a great reputation on FTE.fordborn has a great reputation on FTE.fordborn has a great reputation on FTE.fordborn has a great reputation on FTE.
Quote:
XLTBryan
Not sure what you have but this will work with at least up to th 03's:
1. Start in the truck with all doors closed and the key turned off.
2. Put the switch in the on position and press the door unlock button 3 times.
3. Put the switch in the off position and press the door unlock button 3 times.
4. Put the switch in the on position, you should hear a quick note from your horn.
5. Press the door unlock button 1 time then press the door lock button 1 time.
6. You should hear a short note from your horn indicating that the auto-lock system is disabled. If you hear a short note then a longer note from the horn then the auto-lock system has just been enabled.
7. Turn the switch to the off position. You will hear a short note from the horn to let you know that the system has been changed.
These steps should be done within 30 seconds in order to properly activate or deactivate the feature.
door chime disable tallac19 1999 to 2016 Super Duty 1 07-01-2012 03:10 PM
Disable seat belt alarm sprinter31 1999 to 2016 Super Duty 4 02-09-2009 07:44 PM
Factory alarm system disable cranefxr 1987 - 1996 F150 & Larger F-Series Trucks 0 11-01-2008 01:09 PM
Disabling the Alarm system in a 97 F-250 MASSIVE460 1999 to 2016 Super Duty 2 03-10-2006 06:29 AM
Disabling factory alarm 2004 FX4 samoy 2004 - 2008 F150 4 06-25-2004 08:26 PM
Tags
08, 2005, 2009, alarm, belt, buzzer, ding, disarm, edge, f150, fasten, ford, seat, seatbelt, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
