How can I tell what model transmission I have? - Page 2 - Ford Truck Enthusiasts Forums
Old 01-21-2005, 08:39 PM
branpollard branpollard is offline
branpollard is starting off with a positive reputation.
I've identified the transmission:
The guy at drivetrain.com said its manufactured by New Process/Tremec (which he says is the same company). I gave him the numbers/letters stamped on the side of the tranny and he said its RUG, SMOD (it has a shifter turret mounted on the extension housing). The numbers/letters on the tranny are:
RF-D9BR-7006-AB
ACE/CO 2
C-2604194
There are also numbers/letters stamped on the portion of the rear extension housing of the shifter, they are:
RF-EOTR-7F306-AB
C-2604302
FA1
A rebuilt replacement from drivetrain.com is one thousand, after you return your core to them.
I'm also considering installing a rebuilt toploader 4-speed, which would be fifteen hundered from David Kee Toploader Transmissions (can't get a core refund).
A third option would be finding a used toploader, but I want to find one that would be a bolt-in replacement, without modifying the driveline, or anything else.
Can anyone offer any suggestions on strategies for finding the right-sized toploader transmission?
Old 01-22-2005, 02:43 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
Ones that came out of rachero/fairlanes are a bolt in replacement, but then again they are all about the same lenght, its just there's tailhousing that put the shifter in different locations, so you need to get a flat center piece (that removable pieceof the floorpan) If you check out my gallery out you can see about where one of a rachero/fairlane puts the shifter at: http://www.ford-trucks.com/user_gall...7&albumid=4022.
But i didn't any problem with the mounts or the driershaft lenght at all (both tranny use a slip yoke and not a steady bearing type d-shaft) but the toploader is an inch or two longer but its not enough to make a difference. But just to make sure they are going to be about the same lenght (as i'm not 100% sure on the tailhousing lenght) measure the length of you tranny and compare it to the toploader if you decide to get a toploader.
The one thing you will have to do (if want the shifter to be in a comfortable spot, as the shifter handle that comes with them are not) is make a shifter handle, its not hard and only took me abouta half hour for the one you see in my gallery (i've since junked that one as i now have a new hurst shifter), i had to weld the bottom wedge thing to the bottom and cut threads on the other end for a t-handle.
Timing Issues - 302 hukdonquack Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 243 07-16-2008 07:40 AM
Anyone use Les Schwab tires/lift? deadfish88 1999 to 2016 Super Duty 4 01-18-2005 10:48 PM
overdrive button problem fordgta Electrical Systems/Wiring 9 01-17-2005 07:12 PM
1995 460 heads?? black460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 12-06-2004 06:50 PM
Wanna get rid of my granny... gear Bart8109 Clutch, Transmission, Differential, Axle & Transfer Case 4 08-06-2004 07:52 PM
Tags
7006, ab, d8br, f150, ford, fotp, identify, rf, rfd9bb7006ab, rfd9br7006ab, smod, tranny, transmission, transmition, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
