1977 Ford Bronco (Engine Stalls after overheated) - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 01-17-2005, 07:26 AM
Coondawg1344 Coondawg1344 is offline
Coondawg1344 is starting off with a positive reputation.
I have a 1977 Ford Bronco with a 302. Recently I warmed up the Bronco in the morning waiting for the engine to lower it's idle. Unfortunatly, I went inside and when I returned 15 min later the vehicle was idling at a high RPM rate.
I drove the vehicle about 500 yards when the engine stalled like it was out of gas. I vented the radiator and loosened the gas cap. The truck started and it drove like new.
The next day, once the vehicle heated up it again stalled twice. I made it to work and then after work on the drive home it stalled every 1000 feet. I wait 3-5 minutes and it would start and then 1000 yards later it would stall again.
I was thinking it may be a fouled fuel filter but I can't get why it stalls like it is out of gas. Is there anything on the 302 that will cut of gas supply??? or is it fouled distributor?????
Old 01-17-2005, 10:25 AM
GrayRanger4x4's Avatar
GrayRanger4x4 GrayRanger4x4 is offline
GrayRanger4x4 is gaining momentum as a positive member of FTE.GrayRanger4x4 is gaining momentum as a positive member of FTE.
First WELCOME to FTE!!!
Have you check for a blown head gasget{water in oil,oil in radiator}??You might need to add come coolent to it and find your lick if it is low.JMHO
Old 01-17-2005, 07:52 PM
Head Gasket is fine. I know it needs a new Thermostat but I didnt think that the thermostat could cause the engine to stall. I am sure it is some componant that is getting overheated, I just cant figure out what it is.
Old 01-17-2005, 07:54 PM
3broncocrazy's Avatar
3broncocrazy 3broncocrazy is offline
3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.
vapor lock? if the engine is running hot and the gas line is getting to hot.......could cause it to stall
352 / Holley Help please jav409 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 02-13-2005 03:00 PM
Need Some help from the X guys! Bugeater Excursion - King of SUVs 16 02-05-2005 12:39 AM
97 f150 (#1 cylinder misfire) shivan22 1997 - 2003 F150 8 01-11-2005 12:35 PM
No start on 4.6L 2000 Expedition Roland Donnell Modular V8 (4.6L, 5.4L) 3 11-14-2004 11:13 AM
fuel delivery probs estearly Fuel Injection, Carburetion & Fuel System 0 09-06-2004 09:03 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1977, 1996, 79, bronco, broncodelaware, dies, engine, ford, hot, overheated, shuts, stall, stalled, stalls, taurus, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
