96 Cummins 12Valve into an '88 F350
#31
so basically just reuse the gas harness to hook up the guages? I was thinking that way, just wasn't sure. I also was wondering on the fuel tank and pumps, if the electric pumps supply too much pressure, or if I can leave them, then whether to use the mechanical or not. I have the tank from the Dodge donor, but it would be nice to retain the dual tanks.Thanks for the info, I thought I knew what I was getting into, but is proving to be a little more than expected, but that's the way these things seem to go. I'm not new to conversions, but gasoline injection is a PITA for doing this...
#32
Danny
#33
That was what I figured, I thought the pumps were too high pressure and not really compatible for diesel anyway. I'm hoping to be able to reuse the Dodge tank and lines, I have to extend the lines as the donor was extended cab, the recipient is a crew cab. I already figured out the switching is different, instead of having an actual switch, it turns off the pumps, must be check valves somewhere in the system to prevent transfer to the other tank... My father has an 84 that I can probably rob some of the parts from to make it work, just for now it will end up being single tank. Have to see how that works out as to whether I bother with the second...
#35
#36
Thought I would revive this thread to share some links to help anyone wanting to do this kind of swap... http://www.cummins-conversion.com. http://www.autoworldmt.com Cummins conversion is quite informative, finally saw some pics of the motor mounts so I can more easily figure mine out. They aren't too keen on fordcummins products and workmanship, they direct more to the autoworld parts, or Reliable Diesel of Mesa, Arizona, but I have yet to get a call back from them...(Reliable Diesel)
k_brenner
06-11-2013 06:59 PM
ReBilld
44
02-11-2012 03:51 PM
