You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I've been shopping for a slightly better roller cam for a 94 351W engine I came up with. But there isn't a whole lot to choose from. The W seemed to drop off the aftermarket map in 1994. So far I've only really looked at Summit and PAW though. I see some mention of the Lightning replacement cams but they apparently are listed as "flat tappet" cams. My W came from some old 1-ton work truck but a friend claims to be building a 94 Lightning engine that's a roller cam. From the parts catalogs it appears that it could be a Lightning engine or a roller cam, but not both. Is this true? And if so, why? I can't imagine all the work Ford put into a Lightning and not giving it a roller cam while the work trucks got them.
As far as cams, I'm thinking Ford's E303 5.0 cam is looking pretty good. I want to add some more fun to a plain old daily driver F150 that's already a bit faster than it needs to be. But I don't want to compromise the truck's ability to get a little serious work done now and then. Any better suggestions?
Welcome to Ford Truck Enthusiasts!
See you on the boards.
Enjoy FTE ..
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
Now why would that be do you suppose? I still can't believe the Ford/SVT guys putting roller cam capabilty into the Lightning and then not using it. If I were the lucky owner of such a truck, fitting a roller cam would certainly be #1 on my to-do list.
My guess is because they didn't want the Lightning to have more power than the Cobra.SVT just handled the marketing of the first gen Fords truck division designed and built them.Thanks for the welcome.
That's right I have a 94 lighting . Just did a intake gasket & it has the hole's for the roller's i'm selling mine It has sat for 1 year i can't let it just sit Selling cheep $ 8,000. just to let it go .
Don
__________________
1965 F100 Custom Cab w/ 39,000 orginal miles . This ride replaced a 1994 Lighting W/ 79,000 miles.
They probably did it because the "marine" cam was easier to get past emmisions and cheaper to produce.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
I stumbled across an answer to my question.
Apparently supercharged (and turbo'd) engines respond a lot better in the lower rpm ranges to a cam that can provide very quick initial valve lift. "Flat" cams surprisingly do this better than roller cams. Using 1.7 rockers instead of the more common stock 1.6 ratio rockers also helps. All this adds up to a Lightning having more "streetability" and the capability of doing some actual truck-like work. I think the Ford engineers were right on the money with this as you lucky owners can probably testify. How many Lightnings were bought to be fun daily drivers capable of doing some light work if needed? That's what I would buy one for.
Roller cams aren't bad in a boosted application, they can easily outperform a regular cam in the upper rpm ranges. Exactly what you'd want if you only use your Lightning to blow away competition and never to pull a trailer.
Well, I learned something today. A good day
I pull a trl. with my bronco & it now has a roller camshaft you are telling me that my bronco is better off with a flat tappet cam ?? I can tell you my engine crank's much faster w/roller, smother running w/ roller engines have less friction w/rollers , than flat tappetsI just can't figure out where flat tappets are better than my roller ??????? Pulling a trl. or not !!!!!
Don
__________________
There is no application that is better suited by a flat tappet cam than a roller.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
I know i dont have a lightning but on the topic of cams i have a 1995 f-150 302 w/o mass air now what kind of cam would i have a rollor or flat. Wich is better for a lifted truck with 35's. Well thanks alot
__________________
1995 f-350 4x4
7.3 stroke, w/ tony wildman 6 stage chip, pyro,trans temp, and boost gauge. MSRP 4in exhuast turbo back, 35 in bfg's
Gen 1 Lightnings AREN'T supercharged? Blows that theory. Perhaps I'd best stay out of the Lightning forum.
Oh, and Whitezmbie, your engine IS a roller cam. I wouldn't mess with it, enjoy.
