Belt removal - tensioner won't move
Old 01-16-2005, 10:10 PM
stein78's Avatar
stein78
stein78 is offline
Well I feel like a moron, I can't get the belt off my 5.4L truck. I have a 4.6 mustang and have had the belt off a dozen times so I am not sure why I am having trouble here. When I put my 1/2" drive wrench in the whole and try to go clockwise with it to move the tensioner to get the belt off, it doesn't budge. I yanked on it pretty good, but it still didn't move. The one in my mustang is much easier to move.
Am I doing something wrong? I know this shouldn't be difficult. If it means anything, it's like 10* outside.
Old 01-16-2005, 11:05 PM
bosshoss's Avatar
bosshoss
bosshoss is offline
HEY.
The belt tensioner might be frozen, might need to replace it. just a thought. Good luck.
DP.
Old 01-16-2005, 11:13 PM
Ghostgunn's Avatar
Ghostgunn
Ghostgunn is offline
My did that at first on the 4.6 f150 1999, then it gave .. I would just replace the whole thing they are not very expensive. May as well get rid of you problem now as how it bite you later. depending on the mileage you probably need to anyway. Was very simple on mine.
Old 01-20-2005, 09:37 PM
dlorenz's Avatar
dlorenz
dlorenz is offline
The tensioner on my '97 4.6 F150 is pretty stout - used a 15" breakover and it took a fair pull to move it - wound up using a cheater to make it easier to hold. I also found that I needed a tool to help me manipulate the belt off and on - made an "L" shaped hook out of some 1/8" rod.
Old 01-20-2005, 10:06 PM
stein78's Avatar
stein78
stein78 is offline
I was able to get the belt changed out. I used my breaker bar and a different angle and was good to go. Thanks!
Old 01-31-2005, 07:46 PM
byo71's Avatar
byo71
byo71 is offline
i use the handle for my hi-lift over my 1/2" ratchet. works every time.
diesel_dan
05-28-2015 10:52 AM
tiopet
04-02-2013 01:20 PM
tonyhd
1997 - 2003 F150
04-01-2011 09:25 AM
formula74
2004 - 2008 F150
03-23-2010 02:24 PM
Alpine6
18
03-11-2008 04:33 AM
Quick Reply: Belt removal - tensioner won't move
