what engine can I put in my truck
I'm looking for some advice on changing the engine in my 1994 F-150,4x4,automatic. It currently has a 302, 5.0 . What I need to know is, what other motor would fit. Can I use a an engine out of a car? And if so, what engine? If not what year truck engine could I use ( from what year to what year?)
What is your goal.
A regular 302 will fit without any modification. A 302HO or 351W will fit if you change computers and exhaust, and a 300/6 will fit if you chagne the motor stands, exhaust and computer. A 460 will require a different tranny, mounts, stands, headers, computer, and radiator.
Welcome to FTE!
Welcome to FTE!
Thanks for the info! The reason I want to change the 302 engine is that, in the past few years I've had several problems with knocking motors (90 Ford Bronco, 2- 94 F-150'), all had the 302. I was told that a 302, out of a car, would not fit because the block and the front of the engine is the opposite of a truck engine?!???!?!?!? One more question for you..... If I go witht he 351W, will I have to change the electric fuel pump as well? Any help you can give is appreciated!!!!!
Originally Posted by Mattsbox99
What is your goal.
Welcome to FTE!
Welcome to FTE!
ss27gogeta
11-08-2015 03:45 PM
cwmerc88
08-16-2002 11:39 AM
