Curb Weight vs. GVWR - Ford Truck Enthusiasts Forums
Old 01-16-2005, 02:41 PM
zr800 zr800 is offline
zr800 is starting off with a positive reputation.
Unhappy Curb Weight vs. GVWR
Please help me understand these numbers to be CORRECT. My 2004 F-150 FX4, 5.4, 3:73 has a curb weight of 6500 lbs. Sticker on driver's door post says GVWR is 7200 lbs. Net carrying capacity without passengers, fuel etc is 700 lbs???????????? Severely inhibits towing capacity??? I am looking at towing a fifth wheel trailer and all pin weights of the smallest trailers are greater than 500 lbs unloaded???
Old 01-16-2005, 03:08 PM
ctfordguy ctfordguy is offline
ctfordguy is starting off with a positive reputation.
Where did you get that curb weight from. I have a 8' SCAB 4X4 , a bigger truck and my truck with a full tank of gas and some garbage in the back usually is around 6300 lbs on the dump scale. I fiquire mine has a curb weight around 5900-6000 with me and a full tank.
But if that weight is correct then your conclusion of 700 lbs of capacity is correct.
Old 01-16-2005, 03:21 PM
Scott_XLT Scott_XLT is offline
Scott_XLT is starting off with a positive reputation.
zr800 -- Assuming your truck was empty, your curb weight of 6500 lb must be incorrect. Looking through the factory specs for the 2004 F150 (available on this website), curb weights of empty trucks ranged from 4788 lbs for a regular cab short box 4x2 configuration to 5502 lbs for the 4x4 SuperCrew. Better go back and check that 6500 curb weight figure. I'm sure you will find that you have more payload capacity than you fear.
Old 01-16-2005, 03:26 PM
Thanks guys. Should have mentioned that my truck is a SCAB. What I am seeing in the Specs section on this site is 6495 curb weight. Or am I reading something incorrectly????
Old 01-16-2005, 03:53 PM
bdmcdonald bdmcdonald is offline
bdmcdonald is starting off with a positive reputation.
According to the spec sheet that came with my 2004 SCAB, 5.4l, 4X4, 3.73 rearend, 6.5 ' box, the truck weight is 5115 lbs. The GVWR is 8200 lbs(Trailer tow Package). The max loaded trailer weight for this truck is 9300 lbs. With a 20% hitch weight of 1860 lbs you won't exceed the payload of 3085 lbs.
Old 01-16-2005, 03:55 PM
Quote:
Ahh, I see that I missed some of the higher curb weights (my range should have gone up a bit higher for the 5.4L models). My mistake.
However, I think it is safe to say that the 6495 figure is a typo -- it should read 5495 lbs. If you look at the numbers before it and the number for the supercrew, which would definitely be heavier, it looks like a typo to me.
Old 01-16-2005, 04:07 PM
bdmcdonald,
You better read your spec sheet again. All trucks with a 8200# GVWR have an 8' bed and 4.10 gears, it is called the Heavy Duty payload package and is separate from the trailer towing package.
Old 01-16-2005, 06:17 PM
bonx00 bonx00 is offline
bonx00 is starting off with a positive reputation.
According to the 2004 Ford F-150 Brochure: Your FX-4 SC with 5.4 will have a 7300 # maximum towing capacity if you have a 132.5" wheel base. I got that figure from looking at the chart on PG 41. The chart shows 7800 # for a 4X4 SC with 5.4 and 3.73 rear/ 132.5" WB. Under the chart it states to reduce max weight by 500 # for FX-4 and Lariats with 18" wheels.
The chart also states that these weights are figured for conventional towing (meaning towing from bumper hitch) I see where you are wanting to tow a 5th wheel type trailer, that will only change the weight ratio between the axles on your truck and not change the total weight of your trailer any.... obviously, so I would imagine that if you still stay within the 7300 # you should be fine
If your truck is 144.5" WB, it bumps your max tow weight to 9300#, 8800 for FX-4
Hope that helps you out
Old 01-17-2005, 12:35 AM
exiled's Avatar
exiled exiled is offline
exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.
both my 04 @ 05 scab 5.4L full tank truck mt came in @ 5700lbs on the scale at the grain elevator which i trust cause we have them checked every 60 days...
Old 01-17-2005, 03:16 PM
Smile
I'll check again, but the sheet I got was from the dealer and it didn't mention the 8' box. I think my truck is only 7200 LBS GVWR anyway.
Old 01-17-2005, 08:49 PM
Thanks for your input guys, I will scale my truck this week and post weight, obviously there must be a typo in the spec sheet posted on this site regarding curb weight for my truck
How Much Can I Safely Tow? beanstock2 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 17 11-29-2015 04:43 AM
towing capacity ford f-250 diesel fx 4 frenchsylvain 6.0L Power Stroke Diesel 2 06-19-2011 08:41 PM
Triton V-10 and Popular Mechanics Test Wolfboro Modular V10 (6.8l) 8 11-19-2010 11:15 PM
Comparing '89 & '06 F-250 GVWR, not much difference...hmmmm... stevenn1 1999 to 2016 Super Duty 18 05-11-2008 05:57 PM
Towing capacity Mike O. 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-09-2007 10:52 PM
Tags
2004, 6500, curb, f150, gvwr, trucks, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
