can you temporarily patch a fuel line? - Ford Truck Enthusiasts Forums
Old 01-16-2005, 11:24 AM
winchester2 winchester2 is offline
winchester2 is starting off with a positive reputation.
The fuel line has a leak. Can I temporarily patch the fuel line for a week?
Any and all responses are appreciated.
Old 01-16-2005, 11:46 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE ..
Old 01-16-2005, 02:26 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
What are you working on??
Old 01-19-2005, 09:26 PM
angus angus is offline
angus is starting off with a positive reputation.
I don't know about high pressure FI lines, but it works OK with low pressure fuel lines. The line had rubbed against a clamp and worn through, so I got a chunk of fuel hose, split it lengthwise, and hose-clamped it over the leak. It held.
Or you could cut out the bad section, flare the cut ends, and splice in a replacement line using couplings. If that works for brake line, it ought to be good enough for high-pressure fuel lines too.
Old 01-20-2005, 04:01 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
It sure helps if people give a little info with their questions...
Old 01-21-2005, 12:01 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
We really need to know what you are working with to be able to help
49 merc flathead zrae 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 11-08-2016 10:07 PM
How can I temporarily disable the rear brakes? 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 20 08-12-2015 02:49 PM
fuel line olives Onus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 10-20-2012 10:01 PM
Patch panels pintoches 1978 - 1996 Big Bronco 7 01-12-2012 04:07 PM
Seat fabric repair dchamberlain 1999 to 2016 Super Duty 1 01-28-2011 12:06 AM
Tags
emergency, fuel, high, hose, leak, leaking, line, lines, linesplice, pacthing, patch, patching, press, return, temporarily
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
