5.4L whistle? - Ford Truck Enthusiasts Forums
5.4L whistle?
Old 01-15-2005, 10:49 PM
Lund50 Lund50 is offline
Lund50 is starting off with a positive reputation.
5.4L whistle?
What would cause a whistle sound from under the hood at about 1400rpms?It only does it at that range,not more or not less.I just started hearing it about a week ago.Is it the colder weather or whats up?Thanks,Joe
Old 01-16-2005, 03:06 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Could be a vacuum leak. Check the PCV hose for cracks especially behind the intake in the elbow. You don't have a TB spacer installed do you?
Old 01-16-2005, 07:18 PM
LxMan1,I went over all the hoses,I'm going to run out and double check behind the elbow.
Old 01-16-2005, 08:32 PM
fireman28's Avatar
fireman28 fireman28 is offline
fireman28 is starting off with a positive reputation.
Do you have an after market coldair intake?
Old 01-16-2005, 11:40 PM
ssKable ssKable is offline
ssKable is starting off with a positive reputation.
check your throttlebodie and make sure its bolted tight, mine was doing that and I found a loose bolt so the gasket between the elbow and the trottlebodie was sucking air in and making a whistling noise, tightened the bolt and it went away.
Old 01-19-2005, 05:57 PM
The whistle went away the past couple days.I was thinking because of a little warmer weather,but I wonder if it is a loose bolt in the throttlebody,I will check.
Old 01-25-2005, 12:05 PM
Jake58 Jake58 is offline
Jake58 is starting off with a positive reputation.
Have you checked your radiator fan clutch? Mine is making sort of a humming noise and the sound changes with the spped of the fan. Several folks have told me it sounds like the fan clutch is going.
Old 02-03-2005, 03:08 PM
birdmayon birdmayon is offline
birdmayon is starting off with a positive reputation.
Did you ever figure out the problem? My 5.4 also developed a whistle recently, only when it's cold. Once it warms up it goes away. Also never happens on warmer days. It only happens in the 1900 to 2200 rpm range...sounds like one of those plastic tube kid toys that whistle when they spin around. It's been too cold for me to bother checking the PVC hose but I'm hoping that's the problem. My engine has 48k on it.
Old 02-04-2005, 05:20 PM
crz crz is offline
crz is starting off with a positive reputation.
2000 model 5.4. Mine has had that same whistle since I bought it sveral months ago. 1900-2200 rpms under light load. I asked around where I live and others have the same issue ........ so I thought it was the nature of the beast.
Old 02-12-2005, 05:07 AM
Crown Man F250 Crown Man F250 is offline
Crown Man F250 is starting off with a positive reputation.
REPLY TO ALL HAVE YEA CHECKED FOR A BROKEN exhaust MINIFOLD STUD.
Old 02-15-2005, 06:30 AM
BACK AGIAN. THE 5.4L whistle YOU HERE MAY BE FROM THE AIRINTAKE TO THROTTLE BODY. I JUST CLEANED THE *** OUT OF MY THROTTLE BODY AND ALL BREATHER LINES. I HAVE A K&N FILTER PACK INSTALLED. ANYWAYS I HEARD THE SOUND ON MINE AGAIN AND IT WILL BE HEARD AROUND 1400-2000RPM. BEING MANULE THE SOUND WILL COME BACK AT LOW RMP AND WHILE ITS UNDER LOAD IN HIGHER GEAR. IT WILL GO AWAY IN HIGH RPM.
WAY TO HEAR BY TEST. UNDER THE HOOD, TAKE THE BLACK COVER OFF THE THROTTLE BODY(THERE IS PINCH CLIP HOLDING IT ON PRESS AND PULL OUT COVER) START BACK UP AND PLAY WITH THROTTLE ON THROTTLE BODY MOVING BACK AND FORTH A LITTLE. LISTEN FOR SOUND AROUND TB AIRINTAKE.
Whistle while you work, have a dwarf whistling on higher speeds HiZ Excursion - King of SUVs 14 01-23-2016 03:31 AM
Whistling noise ??? big-head 6.0L Power Stroke Diesel 3 10-23-2015 03:07 PM
F350 460 pinging under load gring 1987 - 1996 F150 & Larger F-Series Trucks 7 09-01-2010 08:25 AM
Whistle at Idle - What is causing this? whalerron 6.0L Power Stroke Diesel 19 06-01-2010 11:08 PM
Strange Whistle, (possible intake leak) 81-F-150-Explorer Ford Inline Six, 200, 250, 4.9L / 300 8 06-10-2009 10:10 PM
Tags
04, 2000, 2009, 54, 54l, 54whistle, 97, cold, engine, f150, ford, liter, noise, rpm, series, whistle, whistles, whistling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
