07-16-2008, 04:45 AM
Check to make sure you're getting 12V at the injectors and that the ECM is powering up. Also make sure you have the plug wires in the correct firing order. The 94 probably has the 1-3-7-2-6-5-4-8 order while the 89 (if it's from a truck) has the 1-5-4-2-6-3-7-8 order. It should at least sputter, though, with the wrong order.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
