Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-15-2005, 01:16 AM
mottj is starting off with a positive reputation.
explorer van rotor recommendation
I am new to the forum and have been trying to determine the best rotor for a explorer conversion e150. i purchased 2 of the value craft rotors, being cheap, and have had second thoughts about using them. As I recall the last time I had the rotors turned, the bearings I took out were thicker than the ones i got at auto zone for these rotors.
Does anyone know if the rotors on the conversion vans are stock or does conversion companies like explorer upgrade the components?
What rotors would someone recommend. I saw in past posts that power slot ($124) was what somebody else recommended. I saw that jcwhitney had slotted and drilled for $99. This thing is heavy and needs help in the stopping department.
Thanks,
  #2 (permalink)
Old 01-16-2005, 08:01 PM
swgaspidey is starting off with a positive reputation.
You can check to see if the bearings for the e250 or 350 will fit your spindle and rotor combination if you want to but if you don't want to spend the big bucks for the slotted rotors the stock should work fine. And the stock bearings will work fine on your conversion van.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
