06 Lariat Possible Fuel Pump and/or Injector Issue?
Old 03-07-2017, 08:43 AM
Amir's Avatar
Amir
Amir is offline
I've been reading posts on this forums for a few months now and this is my first real post (I posted in the Introduction thread). I recently purchased an 06 Lariat and have been slowly working on tackling some of the issues it had. It had a ticking noise, which I thought was for sure the cam phaser, but the ticking was gone after I changed the plugs and coils. Anyway, I won't ramble.
The real issue I'm still having is while driving, I have a slight loss of power coupled with a grumbling (instead of normal engine revving while driving). If I let off the accelerator and get back on it, the car functions normally again (until the issue happens again a few seconds later). If I don't let my foot off and push it harder, the engine will come out of the grumble with a high rev and the car will continue to function normally. This will happen a few times each drive. In addition to the plugs and coils, I changed the fuel filter and the throttle body (not for this reason...tps was shot). The fuel pump control module was changed by the previous owner (it's a Dorman).
Could this be an issue with the fuel pump and/or the injectors?
Old 03-12-2017, 09:04 PM
442w30's Avatar
442w30
442w30 is offline
Check my posts on other threads, DO NOT ignore this as this is the exact same thing that just happened to me but it did not stop...Injector was stuck and wiped out the engine by the time I could pull over....pretty much grenade the motor short of poking a hole in the block, even broke the motor mounts!
Old 03-12-2017, 10:00 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
My bet is a faulty coil.
The only way you see which cylinder it is is by using a Scanner to look in mode 6 at the test that contains the misfire counts for every cylinder.
The one with the high counts is suspect.
The reason is does not set a code is because it's not a hard fault but comes and goes. The PCM cancels the misfire counts when it goes away.
The cause usually is a coil with shorted turns. The coil still fires but is low in output.
Good luck.
Old 03-13-2017, 08:42 AM
Amir's Avatar
Amir
Amir is offline
I was actually leaning towards the fuel pump. So you had these exact symptoms? Any chance a faulty pump caused the issue with the injector?
Good luck.
I checked this already. No misfires. Looked at the count. Every cylinder is at 0.
Kalando82
1997-2006 Expedition & Navigator
07-20-2019 12:06 PM
creature13
1999 to 2016 Super Duty
08-25-2014 07:26 PM
CanAm09
2004 - 2008 F150
01-16-2013 06:04 PM
rdwebb
Modular V10 (6.8l)
17
03-12-2008 10:09 AM
Quick Reply: 06 Lariat Possible Fuel Pump and/or Injector Issue?
