Molded carpet
Welcome to FTE!!! I got a kit from JC Whitney and it's by NPI or something like that. Nylon pyle cut i think thats right. It's good quality but not as plush as my original carpet. but i had upgraded carpet in my truck being as it were a special edition called the Explorer. I would definately buy it again. Nothing wrong with it.
-Aaron
Edit: the molded carpet is great because you pretty much just take out the old carpet and put the new in the truck and your good.
-Aaron
the pad comes on this capet that i bought. It's only on the front though were you feet are. Under the seat there is none. And the original had none under the seat either.
this one that i bout was rolled up into a log about 12 inches around. and once i took it out of the box i could have put it right in the truck because there were absolutely no wrinkles in it. So it came in a box about 4-5ft high and 1ft square. So a rectangular box.
I reccomend it because of the ease of not having to hang it like i have heard from others. Also there are the cutouts for the shifters marked on the back so you cut them for a perfect fit.
-Aaron
-Aaron
Yeah it was NPI and i just put it in about a month ago and it's as good as the original. I didn't put any sound barrier under it as the pad is glued to the carpet and comes in one piece. the pad is a heat and sound reducer in one. seems to work just fine. Go for it if your gonna do it. only took me about an hour to install it and another hour of prep. so 2 hours is pretty much how long it's gonna take.
-Aaron
-Aaron
