Ignition modules failing-fix it or carry a spare
I am reading more and more posts that point to bad ignition modules. It must be that they were designed to last 20 years. I fixed my 1980 f150 three years ago. When the same symptoms appeared last summer on my 1983 Crown Vic, I knew exactly what to replace.
The f150 died at 2am after fishing. After walking for and hour I called a friend to come get me. We went back to the truck and it started right up. The next day I bought a new module and duck taped it in place. It has run perfectly for 3 years now (yes I eventually installed it w/o the tape). Point is, if you have an 80-86 F150 and it has not failed yet then you are on borrowed time. Go get a new one and be ready. I bought a B/W part.
What do you want from an electrical part that's in such an abusive location as next to the engine. The temperature can range from below zero to 200+ deg in a matter of minutes. Vibrations, dirt, oil, & water.
20 years great- even 10 years seems pretty good to me.
Just my $0.02 cents worth.
I'm with you. My 1986 F800 used to not start once in a while or quit running. I did the usual testing then got my hands on a Mitchell Ignition Manual. The manual stated that if the engine died for no reason then change the module. I did and never had a problem again.
Of course we all know that the '80's were a testing ground for newer computer ignition systems and we all pay (paid) the price for new technology.
Dr_j
Dr_j
