where are the IAC AND MAF sensors in a 1996 ranger?
depends on which engine you have. generally the maf is right next to the air box and the iac is on the throttle body or upper intake.
this is the IAC
i cant find the pics of the maf from previous posts.
the maf sensor is black and flat and is held on with two torx screws, its mounted in between the air box and the air tube, my sensor says "mass air" on it. when you take the sensor off there will be two filliments so be careful they are fragile.
this is the IAC
shultzaberger
1983 - 2012 Ranger & B-Series
04-18-2016 07:57 PM
Ceo4sure1day
18
08-21-2011 09:14 PM
