Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-12-2005, 02:54 PM
Darthange Darthange is offline
Garage is empty, add now
Darthange is starting off with a positive reputation.
Question Change out engine coolent temp sensor 2.3I Ranger 1989
Looking for a good tip on changing out the ECTS on a 2.3I 1989 ranger. I seem from the shop manual it's above oil filter near back on block and below the intake manifold. I can't see nor feel it. Do I have to remove the in-take to get at it??
Andrew
  #2 (permalink)
Old 01-13-2005, 11:04 AM
Smile Come on somebody knows??
Did this one stump everyone. Please answer!!
  #3 (permalink)
Old 01-13-2005, 03:01 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
Two tpyes:
The sender is the one on the back of the engine. I changed one. It is a pain to put back in and you need a load of extensions....all the way to the brake master cylinder. A lot of stuff is in the way on my 94 2.3L. It is under the oil pressure unit. To be sure you got the right one, just check the temp gauge when you've pulled a connector off. The temp gauge will be dead if you got the right one.
The sensor is on front in one of the heater hose lines on the passenger side. Only replace if you have a ECT check engine code and the wiring is in good shape and the sensor is connected. This goes to the computer.
You will be literally under the hood (bowing on the engine to reach the sender. It's okay, but I could not save the coolant from pouring out, but my stepdad and I filtered the pan full that we collected and put it back in.
Good luck.
  #4 (permalink)
Old 01-13-2005, 03:27 PM
bojette bojette is offline
bojette is starting off with a positive reputation.
ECT sensor
I'm trying to replace one on a '91, 2.3L, and I'm having a heckuva time locating it.
I've found it, but how in the world do you get to it? I'm guessing you have to go up from underneath.
  #5 (permalink)
Old 01-22-2005, 10:29 AM
Smile Thanks for the help
I got the ECTS out, but had to remove the oil filter from under to get to it. Thanks for the help.
Andrew
Tags
1989, 23, 89, ect, engine, f350, ford, liter, location, ranger, sending, sensor, switch, temp, temperature, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
