Recommendation for 2004 Expedition stereo upgrade - Ford Truck Enthusiasts Forums
Old 01-12-2005, 01:27 PM
Jonathan Mormile Jonathan Mormile is offline
Jonathan Mormile is starting off with a positive reputation.
Hello. I am looking for a little help recommending an upgrade for my stock stereo in my 04 Expedition SLT.
I am considering these two options:
Option One: I have a Hifonics 2x50watt amp (with built in crossover) that I could use for a subwoofer and just use my stock door speakers for the highs and mids, but I am not sure I want to do that. If I did should I upgrade the stock door speakers or just turn down the bass? (I am not sure I am sold on the SLT OEM door speakers - they sound a little weak) I have a local guy that will build a small box (for a 10" Quantum?? sub - downfiring so to hide the sub, sort of) and he said that the door speakers would be fine, but since I dont have a cargo cover (because of the 3rd row seat) I don't want it to get stolen (because it will be able to be seen).
Option two: Buy a 4 channel amp and upgrade the door speakers with better quality 3 way speakers. Will I get alternator noise/interference from this type of installation? I was told by another stereo shop that they would not do this type of install because the speakers would eventually produce alternator or other interference noise and I would be back at their door complaining (this shop does not do much custom stereo work). I understand that I won't get the same "punch" as having a subwoofer but I am really looking for sound quality over boom (high highs and low lows).
I would really like to go with the second option if possible (the wife does not want a subwoofer box in the back and I don't want to get my stuff stolen since the box will be able to be seen) and would greatly appreciate any feedback from any of you that has experience with this type of application.
Thanks fellas,
Jon
Old 01-12-2005, 04:17 PM
kontai69's Avatar
kontai69 kontai69 is offline
kontai69 is starting off with a positive reputation.
Quote:
The primarily cause of alternator noise (or whine) coming from the speakers is improper grounding of the amp that is driving the speakers. A properly grounded (i.e. properly installed) amp should not give you any problems.
You will need a line out convertor to hook up an amp to the factory head unit...
http://www.crutchfield.com/S-RMR3s84...+out+converter
Old 01-13-2005, 09:39 AM
79wolf's Avatar
79wolf 79wolf is offline
79wolf is starting off with a positive reputation.
kontai69 is correct, alternator whine/engine noise/etc. is mostly caused by inproper installation. Yes, equipment failure will cause it as well, but mostly installation.
You will be a lot happier with your second option. You are already questioning the stock speakers now, and adding a sub (like your first option) will only add that, a sub, no improvement with the rest of the system. Yes a sub is easier to add to a system, but I still say you're wanting to improve the mids and highs first. It may be a bit more costly, and a little more involved, but find a good shop that will tell you changing out the door speakers and adding a 4 channel amp to them before adding a sub is a good thing. They should recommend you do one more thing, and I am going to recommend it as well. Don't keep your factory radio. Adding sub to factory radio, ok, because you're not looking to improve sound, just add thump. If you go through the trouble to add a 4 channel and 4 new speakers, your weakest link is you fact radio, and that is a very weak link. You need a radio with at least 2 sets of RCA preouts, a decent Pioneer or Alpine in the $150 range should have that. As far as speakers go, one thing that most people don't consider is that the rear speakers do not have to match the fronts, i.e. put the best pair of speakers in the front because from the driver's seat that is what you will hear, very little from the rear. Seperate the cost out like 60% front/40% rear, or higher, unless you care about what is sounds like to the people in the back more than yourself lol . Just remember you do get what you pay for in this industry. And that the best equipment installed poorly will never be better than the cheapest system done right.
If you have any more questions, I'm sure there's more that a few of us installers floating around here willing to lend a hand
Upgrades to the stock stereo? cameronf250 2017 Super Duty 76 02-17-2017 05:54 PM
How to upgrade the stock sound on an Aerostar KhanTyranitar Aerostar 51 03-23-2015 07:51 PM
Aftermarket Speaker Questions Koosh Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 5 11-03-2006 09:20 PM
2003 F-350 Stereo Upgrade Advice Please fordrooster Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 08-07-2003 02:53 AM
upgrading speakers gseeders Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 5 01-15-2003 04:55 PM
Tags
2004, custum, expedition, options, radio, stereo, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
