99 Ranger Fan Clutch
I'm trying to change my water pump, in the process I'm trying to figure out how to get the fan clutch off. I know they sell wrenches for this, but i can't figure out how to use the big wrench. The small one should attach to the shaft I can't figure out what to hold with the big one. Looks like it might fit on the four bolts that hold the pulley on. I can't get to those because the pulley is in the way. Can someone help me? Thanks
The two wrenches are called the "Fan Clutch Wrench" and the "Fan Hub Wrench". The Fan Hub Wrench is the bigger of the two, so try and locate the "hub" area where it might go.
Also, on 3.0L engines only, the large nut which attaches the fan clutch to the hub of the water pump shaft has a left-hand (opposite) thread and must be rotated clockwise for removal.
fordka
09-17-2015 01:44 PM
71FoMoCo
1983 - 2012 Ranger & B-Series
05-24-2004 10:42 AM
