Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 01-12-2005, 08:51 AM
Matt_Ranger2000 Matt_Ranger2000 is offline
Garage is empty, add now
Matt_Ranger2000 is starting off with a positive reputation.
Oil Pressure Guage
Hey just a simple question. I have a 2000 Plain Jane Ranger with almost 70,000 miles. About a month ago the oil pressure guage started to act up. When I start the truck the guage doesn't go normal until the truck is warm. Is this a common problem? I know I'm getting oil pressure because the truck runs cherry, just want to know wether it's worth spending the time and money to replace the guage sensor. Thanks!
  #2 (permalink)
Old 01-12-2005, 05:00 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
2002 Ford F-250
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
Well the first thing i would do is get a test gage and remove the sending unit on the engine, and test the oil pressure there and see if the readings are the same. if they are the same, it could be a number of issue's, clogged oil pick-up screen in the pan, oil pump is starting to fail, crank or cam journals are worn, first thing to do is verify the oil pressure by testing it, you can buy these gages at any auto parts store
  #3 (permalink)
Old 01-13-2005, 08:13 AM
Great thanks!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
