Superduty auto-locking 4X4 hubs
Can someone explain to me how the auto-locking hubs on a Superduty work, in-particular the auto part? I recently had trouble with mine and replaced them with a set of aftermarket manual hubs that the manufacturer insisted were the correct application. They worked as far as locking in and out manually, but when I was traveling down the road and hit a bump I'd hear a loud howling noise in the front end. I guess you could say I learned my lesson about aftermarket parts, but I'm curious to know how the automatic part of the auto-locking hubs work on a truck equipped with shift-on-the-fly 4X4? Thanks.
I have been using my autoloc hubs quite extensively with all of the snow in my neck of the woods. I haven't had any failure in attaining 4x4 in the 5300 miles I have on the truck so far. Is there something I should be aware of as far as counting on my 4x4 when needed? I thought that the combination auto/manual hubs were a good idea but sure don't want any surprises when I need good traction.
Originally Posted by 99f350sd
I would say probably 40-50 % don't work all the time.
From what I hear ....
Does Ford know about it? Why do you think they gave us the option of manual lock in the first place.......
Some folks have 10K; some 150K before having trouble with their hubs. There's a few reasons for such a widespread and one is lack of use. Another is how the truck is treated - if driven harsh on rough surfaces the front wheel bearings wear out quicker causing the vacuum to be ineffective due to bad seals and such.
If you get aftermarket - as stated - the Warns are the best buy at somewhere between $175 to $200 per set.
I happen to agree with 99f350sd on the percentage failing. Note he said "all the time", which means they may work fine for a week, then just refuse to cooperate all of a sudden...out of the blue, then they just might kick in next time. At least I'm pretty sure that's what he meant.
In the same vein....I've been fighting a battle with the lock out on the passenger side. At first when in free mode it would howl whenever I hit a bump...then would do it progressively more often, bump or no bump. With y'alls help i got it pulled, cleaned up, greased up and reinstalled. Everything in it looked fine and I chalked it up to just having dry bearings. Went fine for a couple weeks, now an intermittent noise is back, not the howl, but a rumbling like the gears in the lock out are just barely hitting each other. Recycler wants too much for a used one....$125. Anyone ever try to rebuild one? Do they have individual parts available like the bearings and the race, or does Ford make you buy a whole new set?
Ideas? Thoughts?
Thanks.
Steve
99 Superduty CC V10 XLT Lariat
Ideas? Thoughts?
Thanks.
Steve
A good share of problems with auto hubs comes from operator control, I've had no ploblems with mine. I only shift it in when i am rolling srtaight and no tire spin. Also, if you don't like the auto hubs save your money. The factory hubs will also work as manual hubs just like the warner hubs.
Ideas? Thoughts?
Thanks.
Steve
Ideas? Thoughts?
Thanks.
Steve
Rebuilding is a pain. I replaced them on a 99 and they still did not work. Turns out that the mechanic forgot to put a .99 cent o-ring on the outside of one to keep pressure. I would never replace them with the stock unit once one went out. They do go out but 50% of the time is still too high but I agree they are junk.
Mine are finicky at best in a 2000 F250SD V10. Sometimes they lock and sometimes they don't. They usually fail when I really need them, or when it's really cold. The left front usually doesn't unlock unless I drive in reverse for awhile or jiggle it myself from underneath the truck. It's a system that my father warned me about, I went with anyway and get the "I told you so" look, everytime we go hunting. **groan**
